My lastest design ^_^
USB to SPDIF and I2S converter based on PCM2707
TX-179 optical transmiter from TOSHIBA
Both coaxial and optical SPDIF output supported, very high performance ISOLATED DIGITAL TRANSFORMER PE-65612 original from PULSE
Isolation is very improtant for PCM2707 application, with a PE-65612 you may get less high frequency pulse/noise from your PC.
I2S output provides 3.3V LEVEL data, you can easilly contact other I2S DAC with this converter
Standard 16bit/48K
Fully assembled and fully test
Price:$45 , paypal fee and airmail shipping included
If you order http://www.diyaudio.com/forums/swap-meet/152913-fs-tda1541-os-dac-kits.html together with this converter, you will get $5 discount ^_^
thanks
Lu
Standard 16bit/48K
thanks
Lu
Will this do 24/96?
ofcourse not ^_^
PCM2707 only support 16/44.1 and 16/48
Hello Lu,
what kind of power supply does it need?
Hi Danny, you don't need extra PSU, the module is USB slef-powered
