I have the same opinion, Ovidiu...any balast resistors, any gate stoppers, long traces to gates...all is the way to massive oscilations and result is obvious...
Pavel Pavel, your English is horrible
no gate stoppers, not any gate stoppers. Yesterday you mystified anatech by exchanging ANY and NO
I know that you care, but the emitter resistors are important, where the temperature coefficient is negative. Here is a positive temperature coefficient resistors, and thermal stability will deteriorate.![]()
Power MOSFET is made up of many cells (transistors), 100thousand and more. As the power MOSFET is heated by power dissipation, its RDS (on) increases. It is important to select the correct voltage MOSFET. I know that no one applied, but I do.
Have a nice day.
I suggest you read this Federmann :
http://www.irf.com/technical-info/appnotes/an-1155.pdf
http://powerelectronics.com/704PET23.pdf
The temperature coefficient of Id becomes negative at very high currents, for operating currents it is positive.
![IRFP240PbF_2.jpg](https://www.federmann.cz/images/stories/Nf/HQQF/IRFP240PbF_2.jpg)
Transistors so selected to have the same characteristics, only those transistors can be used.
As transistors have the same characteristics, sweeping the input voltage, I reach the current limit.
I know that I did not say anything, so your decision is wrong, diodes D101 and D102 serve as current protection.
Have a beautiful night.
As I see, F. never held vertical mosfet on his hands...amazing....
Graf said for what the currents and temperature as UDS.
![cop :cop: :cop:](https://files.diyaudio.com/forums/images/smilies/cop.gif)
There is no need to insult, degrade and humiliate another member just because his/her design is not "as good" as yours. Please, lets make this a civil meeting place befitting our honourable profession.
a) You seem to have some issues understanding what's up. It's certainly not about "mine is better" but about something that puts potential innocent/inexperienced DIYers at risk. I'm pretty sure you would not enjoy assuming responsability for hosting an irresponsibly dangerous design. Also, looking at the author position, this certainly does not qualify as a honest mistake, "perseverare diabolicum" applies.
b) I'm sure you meant "honourable hobby" rather than "honourable profession"
I'll skip for the moment any rants about intellectual property and copyright issues related to the incumbent's site (dutyfully promoted by the author with your generous moderation support), at least until you'll have a chance to review your own policies about.
Id limited at 50A (for Ugs=10V) or more you call protection? Or you saw some schematics with old laterals and copyied it to your "invention"?diodes D101 and D102 serve as current protection.
Please look carefully, you do not have language problems.
TranslateGoogle
Although being aware of the issue, I had not seen those documents before. Thanks for posting! I like their humor by the way...
Figure II-3: Visual Image of the IRF1405Z failure. This type of visual
pattern is more attractive when observed on the surface of the moon,
instead of on the surface of parts that are trying to land there.
Federmann,
just of curiosity can you tell us what is the current through transistors T107 and T108?
And what are the resistor values of R114 and R115?
Thank you!
BTW, does Mr Federmann like Valhalla cables?
Cheers Michael
- Topology Federmann, HQQF-55 ...
