I dedicate audio 40 years, I never disclose their topology until the last years. Here is one of my latest amplifier topology.
Site photos
Technical parameters of PS
Size 108 x 170 mm
Strength 2.5 and 3 mm
Strength Cu 75 and 105μm
Double-sided, plated
Solder mask, printing, tin plating
Technical parameters of amplifiers 4Ω
Driver HQQF-55-502D
Involvement HQQF-55-503W-4-2
End transistors 2 x 4 x IRFP240/9240
Power supply AC 230V + 2 x 48V (I recommend 300 ÷ 800W)
Cooler, thermal resistance of 0.20 ÷ 0.08 ° C / W, according to the transformer
Rectifier bridge 35 (25) A non-PS
Filtration 16 x 1m/100V (16mF ÷ 64mF)
Additional filtering capabilities block 48 x 1m/100V, separate PS
Worm Up Maximum output voltage ± 65V (46V UEF)
Burden, typically 4Ω
Power, maximum 2 x 500W (2 x 250W/8Ω)
Current protection around 17A
BOM components 4Ω!
Amplifier is to dimension the continuous maximum power transformer using 1.5 kW, which is required to use the cooler thermal resistance of 0.04 ° C / W (not recommended)
Technical parameters of amplifiers 2Ω
Driver HQQF-55-502D
Power supply AC 230V + 2 x 34V (I recommend 300 ÷ 800W)
Rectifier bridge 50 (35) A non-PS
Filtration 16 x 2m2/63V (35mF ÷ 140mF)
Additional filtering capabilities block 48 x 2m2/63V, separate PS
Worm Up Maximum output voltage ± 45V (32V UEF)
Burden typical 2Ω
Power, maximum 2 x 500W (2 x 250W/4Ω, 2 x 125W/8Ω)
Current protection around 35A
BOM components 2Ω!
Technical parameters of amplifiers 8Ω
Driver HQQF-55-502D
Power supply AC 230V + 2 x 66V (I recommend 300 ÷ 800W)
Rectifier bridge 25 (35) A non-PS
Worm Up Maximum output voltage ± 92V (65V UEF)
Burden typical 8Ω
Current protection around 8.5 A
BOM components 8Ω!
Size 108 x 170 mm
Driver HQQF-55-502D
BOM components 4Ω!
Driver HQQF-55-502D
Burden typical 2Ω
BOM components 2Ω!
Driver HQQF-55-502D
Burden typical 8Ω
BOM components 8Ω!
I always look at the amplifier's own eyes. I described the causes Transistor sound here.
Federmann Bohumil. Tranzistorový zvuk počítačové simulace příčin jeho vzniku. Perspektivy elektroniky v roce 2009: 26. 3. 2009. Rožnov pod Radhoštěm: SŠIEŘ RPR, 2009, s. 19-25. ISBN 978-80-254-4052-0.
Please add your experiences.
therefore, i'm curious about the distortion versus frequency performance.
I would like to see measured distortion plots vs. frequency and amplitude as well, into 4 ohm.
sorry, you're right allen. i meant to say "I notice there are NO emitter followers to drive all those output mosfets"
i notice there are emitter followers to drive all those output mosfets. therefore, i'm curious about the distortion versus frequency performance.
after a quick inspection, I noticed the following:
1) only N-channel MOSFETs: I think, in the negative half you must use P-channel devices by the presently used driver topology
But better solution it must be, to use only N-Channel MOSFETs (to get more information, go to my link collection about
http://www.diyaudio.com/forums/soli...better-audio-non-complements-audio-power.html
2) the average connection of the potentiometer for the idle current to the base to the transistor for the variable voltage source isn't a good solution, because the max possible idle current (shorting current of your power supply) runs through the output devices in case of a pot-break. Replace your potentiometer between base and emitter and introduce a fixed resistor between collector and base to this transistor. This must be done always, not only in this case.
But the input circuit looks very interesting
Characteristics of my drivers HQQF-55-502D, amplification without feedback. I set up to focus on flat transmission characteristics. Warning phase characteristics of the different scale
The input circuit is pretty conventional isn’t it?
What about gate stoppers?
Cheers
Characteristics of drivers HQQF-55-502D feedback and intensifying 26dB, is worth noting a very small phase angle in the acoustic band, watch a different phase characteristic scale
Cheers
you are right. the kind of schematic drawing got me confused - it is a mirror symmetric differential amp for high open loop gain, that is find in some amps.
Current form, the assessment and fitting end transistors. He will be measured.
- Topology Federmann, HQQF-55 ...
