Can this Rockford amp be fixed?
It has a blown imput circuit. I won this on Ebay for the end caps and bottom cover. I was gonna use it as a wall hanger but maybe its repairable? Oh yeah the back of the board is kinda burnt too. This this thing fried pretty bad!
LMK
Thanks!
These are from a 40x2.
http://www.bcae1.com/temp/punch40x2/IMG_2211.JPG
http://www.bcae1.com/temp/punch40x2/IMG_2213.JPG
http://www.bcae1.com/temp/punch40x2/IMG_2216.JPG
According to a friend who was watching the auction, they allowed 12v to contact the RCA jacks (<< second hand information).
One more thing. Do you happen to have a Punch 55.2? Maybe i can locate these parts and try to repair it. And is it hard to install the small surface mount pieces? Like, resistors, ICs, caps?? Thanks again Perry Babin for the help!
There may be no defective components (except possibly the diode that connects the RCA shield to the chassis ground - D7, behind the treble pot in the 40x2). You may only need to cut out the carbonized fiberglass and jump the traces on the bottom.
I don't have a 55.2. I borrowed the 40x2 from a friend.
It's not difficult to replace the SMD parts.
Are you asking where to get acetone? Any hardware store. Even walmart has it in the home paint section. If you use a toothbrush, don't use one that's transparent. The acetone will melt it. Use the acetone outside and let it evaporate completely before bringing it back indoors. It's extremely flammable. Don't let it drip onto any plastic material. It will likely melt it.
