Y2 capacitors for mains isolation
Let's suppose there's an application that only needs a very, very tiny amount of power (less than a milliwatt) for a standby circuit (that applies to a lot of electronics). The circuit that needs the standby power is connected to an externally accessible conductive part so isolation from the mains is required for safety.
Instead of using a transformer or switching power supply (both of which would be very inefficient at that very low power level), what about a capacitive power supply using Y2 capacitors? Y2 capacitors are approved for connection between the mains (either hot or neutral) and device "ground", even if the device does not have a real ground. So connect a pair of Y2 capacitors from the mains to a bridge, then filter and regulate with a zener diode. The idea is that the capacitive reactance would let enough current through to power the standby circuit, while the Y2 capacitors themselves isolate the circuit from the mains. (Note that both the hot and neutral would have Y2 capacitors connected in series so it would remain safe even if miswired.)
If the standby circuit needs a higher current sometimes but mostly stays in a low power mode, a large capacitor can be charged to provide power for those peaks.
Those cases are class 2 isolated equipment with no metallic parts accessible for the user (like a brick laptop power supply). With Class 1 equipment (capacitors are then used for mains filtering) then you are not allowed to defeat ground. Should now a failure occur in the caps, then the circuit breaker or ground protection will (should) provide safety.
A capacitive power supply can sometimes help you out if you need a small milli-amp supply from the mains. Make sure you use only non-metallic parts (switches etc) for user interface and do not allow this power to pass over any galvanic isolation barrier.
Bakmeel
Y2 are safer to use on mains side connections than other capacitors for which you have no safety data.
Y2 do not isolate the mains side from the user side.
They are self healing if overloaded by short term transients upto the test voltage.
They do not short on total failure.
But into a high impedance load they will pass near mains voltage to the user side.
If you can build the WHOLE circuit inside an fully insulating box and there are NO CONNECTIONS to the outside world then you may be able to satisfy your safety criteria.
But be careful. It takes just one wire to the outside world with mains voltage on it to be potentially fatal.
If you put a fuse in front of the cap and a 5W zener to ground after the cap, you have met the UL requirements. This assumes the zener voltage is below their maximum allowed voltage.
Remember, an isolation transformer does not guarantee the unit cannot be deadly if wired incorrectly.
Open up a switching power supply and it will probably have a Y2 capacitor or two from the mains side to the floating ground side, even if the floating ground is not connected to real ground and is accessible from outside. Even switching wall warts often have those.
Are you talking about this? :
That's the EMI filter, which I read to be required in many countries for computer SMPS and other SMPS'es as well.
And yup if the ground cable at the mains is broken and you touch the computer chassis you get an electrical feeling that doesn't kill. :spin:
I think the cap should be Class X or X2.
X2 capacitors are made for connection from hot to neutral. They are not certified for hot or neutral to ground. Y2 capacitors are made for hot or neutral to ground applications. X2 capacitors only need to fail gracefully (no meltdown, meaning that if it fails short circuit, it should self clear) while Y2 capacitors must be designed to not fail short circuit, as such a failure can connect hot to the floating ground.
So all the devices I have seen with Y2 capacitors from mains to floating device ground are not designed correctly?
AndrewT said:
where does this come from?
you said "not designed correctly".
I said "where does this come from".
Your answer has not addressed why you say they are not designed correctly.
So I ask again:-
Where does this assertion that they are not designed correctly come from?
Is this what you have in mind?
