NEW Remote Volume Controller- 10 SETs
so what is the list of items that I'll need to buy here locally with the remote kit? If you seel the power supply how much? Is remote included or do I have to use universal?
Remote handset is included,but you need to build the PSU yourself >_<
please download the manual if you need one ^_^
  • USER MANUAL FOR REMOTE VOLUME CONTROLLER.pdf
Hi All
Could someone tell me, what are the measurements of the part of the display that actually lights up?
If you mean the screen that would show through a cut-out in the front panel, it is approx 72mm x 27mm.
This is on a pcb assembly that is 97mm x 43mm, the screen being symmetrically in the center.
The assembly needs 25mm depth behind the panel.
Is that what you wanted?
the part of display that I marked with black lines.
