Single Ended Active Crossovers for Open Baffle Speakers
Is there such a thing?
I'm interested in experimenting with open baffles using active crossovers, with bi-amped fullrange drivers and woofers.
There seems to be Nelson Pass B4 comming out at some point, also a document that Martin King is working on that deals with active two way crossovers for open baffles, that's not yet out.
I've sketched out a proposal for my system. It involves a JFET source follower (B1 Buffer) before and after a linkwitz riley 2nd order filter. I'm not sure if it's considered to be active. It's a passive filter that is buffered.
I guess the idea is to not have any op amps, and have a system that is single ended with no -ve feedback.
4 input pots could be used to control the level for each speaker, thus providing volume/balance and effective EQ for the full range and woofers.
Does this look feasable? or will there be issues due to DC coupling with excess capacitors in the signal path?
Thanks.
have a look for ´unity gain Sallen Key´. These structures are usually drawn using OP-Amps. But since the OP-Amps are configured to a gain of 1 its easy to change to a simple emitter- or sourcefollower cofiguration instead.
So You´re not bound to only ´buffered passive filtering´ but you can do real active filtering (feedback structures). Passive filtering -regardless of beeing buffered or not- is restricted to low Q values. If You need Qs>1 (Bass-Lift, Equalizers, etc.) You will need active filters. The amount of active parts in Your signal path remains the same, but is of course much smaller than using OPs. I prefer JFET-CCS loaded JFET-Sourcefollowers for the job or Trioded cathode followers. Since we are not talking about measurement equipment, linearity, distortion and bandwidth of a simple follower stage are more than sufficient for the job.
To my taste the simple JFET-sourcefollower-CRs sound much better than any OP based Crossover I came across yet. Especially with bipolar OPs I get the impression of listening to ´reproduced signals´ and not music. Seem to suck out blood and emotions. The simple JFET-buffers though seem to preserve life and emotion in music.
Apart from the sreening and selection of the transistors the effort is basically the same as for an OP amp. Select pairs of JFETs and couple them thermally to get a ´6-pined OP´ ;) Put a couple of resistors and caps around ...voila!
Small, easy and very good sounding.
jauu
Calvin
a L-R 2pole is a cascade of two RC filters.
Each filter requires to be fed from a low source impedance and to feed into a high load impedance.
RC + RC will require a third buffer between them.
The B1 does not have a low enough output impedance to be ignored.
You must take account of the B1's real output impedance in your calculations.
A buffered passive XO. Are you thinking LC or cascaded RC?
dave
Keeping the circuit simple. A LC was what I was thinking. I haven't calculated anything yet. I'm working with MJK worksheets to identify a good woofer to mate with the FE167E driver. OB may be too large in my living room. Looking at other enclosures to work with and/or smaller woofers (~ 10" ). Have you tried with source followers?
music soothes the savage beast
Joined 2004
Hi all,
I have recently finished my line level crossover, 200Hz, which splits the signal for tube amp for midrange and for solid state amp for woofers.
After many itterations, I arrived at the following: signal goes thrue volume control into buffer (IC), than passively splits with LC/CL (stolen design from marchand), than each high and low pass has pot and is buffered again (transistor).
Sounds wonderfull.
Tough part was to get those 2-4 Henry inductors. I ended up using spare 70volt transformers. You know those small transformers which are in the speakers with 70 volt input and few secondaries, like 0.2watt, 0.5watt, 1watt, 2watts, 4watts....for volume...well those are just great for this application. The main advantage over the RC crossover is no signal loss.
Ed
frugal-phile™
Joined 2001
Thanx for the tip Ed... i have a few of those kicking around.
dave
jauu
Calvin
hi Calvin
i have open baffle with FR and 15" woofer and i would like to build active crossover for the speaker (no OP), i like your idea for design "6-pined OP".
you can please help me with a good design that work well with this project?
i prefer simple one :)
what transistors?
The one and only
Joined 2001
You can use the single-ended buffer circuit for the First Watt "B1" and
even buy a kit from PASSDIY.
There is a later variation using PP Jfets, documented around this site.
Alternatively, you can look at the information on the B5 for open baffles with
woofers, checking out the B5 manuals, a product designed for just that.
If you don't want to build, you can even buy one...
:cool:
Nelson Pass
Because of you I have a never-ending hobby !
start with "simple" F5 2 years ago (half year of burning resistor's and learn)
Then figure that i need good speaker for my F5
then figure that i need good DAC to my F5
than figure that i need good buffer\crossover to my F5
it's never end story :)
Thank you
