Making car amplifier SMPS with tl494 + DC Protection
Hello Friends.
I have made Small car Subwoofer + smps based on sg3525
Attached that 150W Car Subwoofer pcb but tahre is some error on the board, After problems solve I will put it hare
:worship: about PCB!!
Uploading pictures, well that is easy
Go HERE and register, username, password..
Then upload picture with big blue "Choose Files"
What so that they upload, you will see progress
then you have 3 links to each picture/video
Direct link - if for say forums, so that user clicks on link like this >> www.dfaj... and it opens picture
HTML code - If you have your own page, this could be something you could use, not usefull for forums
IMG code - This is the one you want, post picture on forum directly
Note that your picture will be < 1024x768, you can choose smaller too.
For PCB, you should save it in PDF, so image will be 1:1, so other can try build it themself if you want that
SEE THIS BEAUTY OF PCB
Hi All,
This my best subwoofer driver kit this is a BTX 250 JBL LPF schematic. The low freq. is dramatic good. just try this with the gainclon or other high power bjt amp.I am designing time channel car amp this time
  • btx 250 jbl lpf v2.pdf
