I was getting some SMD soldering done at a small shop the other day and the guy showed me a tool I should have. It looked like a small set of plastic pliers with a bunch of slots in it. It's purpose was to put the proper bend on resistors and other components prior to insertion in a PCB. Can anyone give me the correct name for this tool or perhaps a Digikey or Mouser part no.?
Dan
Dan
Here you are Dan!
http://www.mouser.com/index.cfm?handler=listproduct&&categoryid=119&lst_pcode=51606
that one is for Through Hole components
Pliers? Something similar to these perhaps?
http://www.toolfetch.com/Category/Hand_Tools/Pliers/EZR300CS.htm?per=15&page=4
http://www.excelta.com/marketplace/browse.asp?category=309
Take a look at 500-102B-US is this getting closer?
Dan
I have used the PR2 which is the predecessor to this tool for the past 30 years. absolutely superb for pre-forming axial leaded components. See PR3 Forming Hand Tool
- Design & Build
- Equipment & Tools
- Help Me Find This Tool
