Originally Posted by roscoeiii
I was delighted that I was able to get jumpers to replace 2 of the 6SN7s and reduce the gain of my amp.
With the lowered amp gain, maybe I will have an acceptable sensitivity in my volume control and improved sound quality from having a hotter source. |
Signal to noise performance is set at the first stage of any amplifier. It can get no better than that downstream, though it can certainly get worse, as the article shows. Complexity is bad; I've no experience with true pro audio, but it seems obvious that complicated (many stages) systems get a huge benefit from standardizing on larger signals. It's a wonder modern PC stuff works as well as it does, given 5V power rails.
[begin dumb idea] We have an environmental chamber at work with a refrigerator and a heater. It controls the temperature by running the fridge full blast all the time, and simply changing the heater power to get the desired temperature. Maybe the ultimate answer is to run the audio system wide open, just below clipping, and put a power attenuator right at the speaker! The numbers work out well unless efficiency is one of them. [end dumb idea]
