Go Back   Home > Forums > > >
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Comments for The Wire - All Boards and Kits Explained Here!
Current Discussion: Main discussion
  1.   #1
    SyncTronX's Avatar
    diyAudio Member
    OPC,
    Can these power supply's and other modules be used with
    some of the Slewmaster modules and amplifiers?
    What are some of the ratings on those units?
    Looking for the threads that support some of those.
    __________________
    -- Sync
  2.   #2
    hochopeper's Avatar
    diyAudio Member
    Hi Owen,
    The image links seem to give me a 404 error (when I open up the link that's shown in the edit page). They look like google drive links, possibly don't have sharing for them set right?
    Otherwise looks great!
    Chris
  3.   #3
    opc's Avatar
    opc is offline
    diyAudio Member
    [QUOTE=hochopeper;4285268]Hi Owen,
    Chris[/QUOTE]
    Hi Chris,
    Images should be working now... it was indeed a Google Drive sharing issue. I was able to see them in Chrome, but not with IE. Now I can see them in both browsers.
    Can you let me know if they're working for you now?
    Owen
  4.   #4
    opc's Avatar
    opc is offline
    diyAudio Member
    [QUOTE=SyncTronX;4284868]OPC,
    Looking for the threads that support some of those.[/QUOTE]
    This is still a work in progress, and there is still a lot to be done! I'll get around to the power supplies later today hopefully.
    The supplies should be able to power anything you'd like, but you need to respect the power limitations. The PSU V2 is good for 1A at +/-32V max (within thermal constraints), the MPUHP is designed for +/- 18V at 3A but can also be modified for higher output voltage. Power in that case is limited by the 50VA transformer. The NTD1 PSU is good for up to 39V output at 200mA.
    Owen
  5.   #5
    hochopeper's Avatar
    diyAudio Member
    [QUOTE=opc;4285319]Hi Chris,
    Owen[/QUOTE]
    Hi Owen,
    Yep, working now!
    Chris
  6.   #6
    SyncTronX's Avatar
    diyAudio Member
    What did you have to do to make the images work properly?
    Then how did you make those tables...they look sweet.
    __________________
    -- Sync
  7.   #7
    hochopeper's Avatar
    diyAudio Member
    Hey Owen,
    Looks like you've got the LPUHP specs showing in the LME49830 amp subsection atm ...
    Chris
    EDIT: looks like you updated that while I was typing this note ... :)
  8.   #8
    opc's Avatar
    opc is offline
    diyAudio Member
    Hi Guys!
    Thanks for proofing this for me while I go. Using this format is very prone to errors, so it's good to have you guys give it a sanity check :)
    SyncTronX:
    I originally put the table data into "tableizer" to get the proper HTML code to make the table, but that didn't work with the Wiki for some reason.
    I did like the way the displayed table looked though, so I grabbed a screen shot and posted it as a picture :)
    Here's the website:
    [url=http://tableizer.journalistopia.com/]TABLEIZER! | Spreadsheets to HTML Tables Tool[/url]
    As for getting the images to work, I just had to share the actual google drive folder the pictures were in, in addition to sharing the pictures themselves.
    I used this to map to to the drive location:
    [url=http://gdriv.es/]GDrives - URL shortener, custom alias for Google Drive Site Publishing web hosting[/url]
    Owen
Moderation Tools (0)
    ".(($imodtools['canapprove']) ? ("
  • ") : (""))." ".(($imodtools['canunapprove']) ? ("
  • ") : (""))." ".(($imodtools['candelete']) ? ("
  • ") : (""))." ".(($imodtools['canundelete']) ? ("
  • ") : (""))." $template_hook[vw_inlinemod_comments]
Hide this!Advertise here!
New To Site? Need Help?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 9.38%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
"Wiki" powered by VaultWiki.
Wiki
