Go Back   Home > Forums > > >
XRK Audio Your source for high performance projects and DIY components: amplifiers, headphone amps, preamps, natural sounding speakers, power supplies, protection circuits, and more
Thread Tools
Old 20th September 2021, 07:12 AM   #231
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Balanced output (BTL) LuFo coupled with a common core dual inductor.
Like this:
XRKaudio Store // Manufacturer’s Forum
Old 20th September 2021, 06:45 PM   #232
Got Foam?
xrk971's Avatar
This is going to need a DC servo circuit to keep output offset near 0mV. I am going to see if I can repurpose the DC servo circuit from the Xmas amp that Jhofland Dibya designed.
Old 20th September 2021, 10:57 PM   #233
Got Foam?
xrk971's Avatar
Both channels of LuFo work! Uneventful firing up for first sound on each channel separately. Then initial tests if balanced SuSyLu shows that bias is stable and output DC offset changes within 20mV through warmup cycle. Balanced common choke appears to be working.
-9f0a948e-9688-4154-9f4f-6db7dd247041-jpeg
-8d9558ae-38bf-44b5-8600-114e44152b30-jpg
-0e9cf3df-1881-4f8f-af0e-91a831c6a418-jpg
File Type: jpeg 9F0A948E-9688-4154-9F4F-6DB7DD247041.jpeg (832.9 KB, 162 views)
File Type: jpg 8D9558AE-38BF-44B5-8600-114E44152B30.jpg (482.7 KB, 516 views)
File Type: jpg 0E9CF3DF-1881-4F8F-AF0E-91A831C6A418.jpg (501.4 KB, 157 views)
Old 21st September 2021, 01:06 AM   #234
poseidonsvoice is offline poseidonsvoice  United States
Poseidon's Voice
poseidonsvoice's Avatar
Here are more updated photos on what my ALPHA 20 board build looks like:
I’ll complete the next one hopefully this week.
Best,
Anand.
NPXP
Science is not a democracy - Earl Geddes; DIYAudio is a journey not a destination!
Old 21st September 2021, 01:42 AM   #235
Got Foam?
xrk971's Avatar
Nice work, Anand!
That’s a fancy cap!
Old 21st September 2021, 06:47 AM   #236
wiseoldtech is online now wiseoldtech  United States
wiseoldtech's Avatar
I've already done numerous amps, both tube (EL84) and impressive SS. (120 to 200w)
Among custom designing some radio gear and other electronic stuff.
So, for a big change, I decided to delve into a small amp for a refreshing change.
Really small, like a couple of watts, maybe 10.
Taken from a trashed reel-to-reel (VM) that had wing speakers, I salvaged the poor little amp board.
Stereo, all class A, 6 transistors (3 per ch) cascaded single-ended driving a pair of output transformers.
Initial testing surprised me, using the test speakers on my bench, so I'm giving it some respectable mods and we'll see how it goes.
Bohemian Guru sagacious, professional.
Old 21st September 2021, 10:17 AM   #237
suresh is offline suresh  India
suresh's Avatar
Anand / XRk ,
IXTK90P20P P channel mosfet has 12nf Ciss. is the gate drive sufficient ? how many milliamps current is required to drive such high gate capacitance.
R.Suresh.
Old 21st September 2021, 10:32 AM   #238
Got Foam?
xrk971's Avatar
Looks like Anand is building the 4 ohm variant of the Alpha:
The IXYS p channel is driven by the VAS, a KSC1845, which works fine. Hugh has often used the combination of a KSC1845 and p channel IXYS with large gate capacitance as a CFP and there is never any issue of gate drive current. Perhaps you can ask Hugh in the Click the image to open in full size. for the Alpha?
Old 21st September 2021, 02:27 PM   #239
Poseidon's Voice
Yes, what X said.
Best,
Anand.
NPXP
Old 22nd September 2021, 06:27 PM   #240
Got Foam?
xrk971's Avatar
On the bench tonight is the SuSyLu max power stress test:
SuSyLu Where Are You?-susylu-max-power-setup-jpg
It worked fine and can run all day at max power. It's Class A so the amp actually runs cooler. Thermal efficiency is 100w/168w or 60%. So at max power the heatsinks only dissipate 68w vs 168w. The opposite of what happens on a Class AB amp.
SuSyLu is verified to put out close to 90Vpp into a 10ohm dummy load:
SuSyLu Where Are You?-susylu-max-power-dmm-vrms-jpg
This is the o-scope trace - yellow is output after a signal divider - actual value is 89.7Vpp. Input signal is 4.64Vpp for overall gain of 25.6dB.
SuSyLu Where Are You?-susylu-max-power-scope-jpg
Thread Tools
Great Lunar Eclipse tonight Pano Everything Else 11 28th August 2007 08:38 PM
Recapped the Imperial 7s tonight geaugafletcher Multi-Way 2 26th April 2006 04:26 PM
Getting ready to buy my speakers tonight... mazeroth Multi-Way 22 29th July 2004 07:16 PM
felt an earthquake tonight ultrachrome The Lounge 3 3rd June 2003 10:14 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
