Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 3rd June 2018, 09:49 AM   #11
freddi is offline freddi  United States
freddi's Avatar
Betsy-K: Big & Sealed
little did I know the power of your wonderful program !!!!! Many Thanks !
Old 3rd June 2018, 04:58 PM   #12
freddi's Avatar
David - how does one select that option to show the axial frequency response?
Old 4th June 2018, 08:57 AM   #13
David McBean is offline David McBean  Australia
Hi freddi,
Calculate the standard power response then select Tools > Directivity > Response, and specify the desired off-axis angle. The default value is zero, which gives the on-axis pressure response. There are five directivity tools that you can play with - have fun :-).
Kind regards,
David
www.hornresp.net
Old 4th June 2018, 09:05 AM   #14
freddi's Avatar
thanks - does that also work for vented cabinets? Regarding front loaded horns, must there be just one segment in the model for the directivity function to work?
Old 5th June 2018, 06:56 AM   #15
The directivity tools work for the individual outputs of a vented cabinet (i.e. the direct radiator output and the port output) but not for the combined output. A front loaded horn must have only one segment for the directivity tools to work.
www.hornresp.net
Old 5th June 2018, 07:01 AM   #16
freddi's Avatar
thanks David for the reply and your time - that's great
Old 5th June 2018, 09:59 AM   #17
d to the g is offline d to the g  United States
d to the g's Avatar
Learned something today!
Betsy-K: Big & SealedHide this!Advertise here!
Dual opposed sealed or two seperate sealed subs? ORNJ Subwoofers 2 17th September 2012 01:48 AM
Sealed FR with Betsy K opa1 Full Range 12 23rd July 2012 11:36 PM
Betsy K in sealed box pboser Wild Burro Audio 5 24th January 2011 09:20 PM
The Betsy Roushon Wild Burro Audio 5 11th June 2010 11:29 PM
50% off to take Betsy where she's never been! pjanda1 Wild Burro Audio 74 8th June 2010 04:42 AM
Copyright ©1999-2019 diyAudio
