Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
DUAL Merus MA12070 fully balanced Amplifier pictures inside
Thread Tools
Old Today, 01:48 PM   #111
Sjef is offline Sjef  Abu Dhabi
Hmm, these reports about noise are worrying me a bit. I have just ordered two A20A's to try in an active speaker setup for mids and highs. They will be acting as power amps with volume somewhere at -10dB to 0dB. Strangely I have read reports from other that say the units are totally silent with volume all the way up. Maybe a difference between balanced and unbalanced inputs?
Well, anyways, if they are hissing too bad they are going to be returned inmediatly. I bought them for a secondary system where I don't want to spend too much time DIY so modifying them is not an option.
Old Today, 01:54 PM   #112
daniboun is offline daniboun  France
Mine is absolutely dead silence, but I am using balanced inputs only.
Dead silence also @ -10DB
You should not have any issue normally.
Old Today, 03:14 PM   #113
I'm planning to use balanced inputs as well. In fact, that's one of the reason I was interested in these units, the balanced inputs.
Old Today, 03:56 PM   #114
Nice you should be happy
Old Today, 06:25 PM   #115
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
The DC output connector is for 15V devices (not 5V).
It's only audio. Member of the non modular PCB design committee.
Old Today, 06:58 PM   #116
SoniCCurrent is offline SoniCCurrent
It's not "noise" in the sense that it would bother you. At least not from your listening position. You'd have to put your ear to the speaker to hear it, even at -0db (loudest). I am using RCA though. Might be totally gone with XLR.
Sure. There are 2x7.5V caps on the PCB. I shot up the 1A fuse so I can't use the 15V backport anymore. Used to plug a RecomRS3 15-5V converter to it to feed my DAC. The Meanwell RPS-400 of which I am elaborating to replace the Mornsun has a 5V/1A out. That's what I meant.
Old Today, 07:26 PM   #117
Thanks for your replies, I'm really curious about the performance of these little amps. I will report back
Well, this and the fact that it has a built-in power supply was a real plus to order them. I really hate powerbricks. I will never ever in my life buy another piece of equipment with an external powerbrick, I am totally done with it, it makes a total mess of a already multi boxed setup.
Old Today, 07:46 PM   #118
........I am elaborating to replace the Mornsun has a 5V/1A out. That's what I meant.
The Murata PQC250-24 is also a choice to consider...
I know that Orchard Audio use them into their BOSC Gan amps. Orchard Audio confirmed their superb performance
But I did not check their size )
PQC250-24 | Murata Power Solutions PQC250-24 Stock available from Infinity-Electron.com | PQC250-24 with Best Price at Infinity-Electron.com
Old Today, 08:16 PM   #119
  Reply to this post
DUAL Merus MA12070 fully balanced Amplifier pictures insideHide this!Advertise here!
Thread Tools
Infineon MA12070 Class D xrk971 Class D 491 Today 06:19 PM
DUAL MONO TPA3221 Pictures Inside daniboun Class D 20 20th June 2021 09:48 AM
LEAF Dual 9038Q2M VS Gustard X16 pictures inside ) daniboun Digital Line Level 19 4th May 2021 11:51 AM
F. Keller commissioned Fully Balanced Dual Cascade Parallel Series 4-way build Cousin Billy Multi-Way 3 15th November 2015 02:36 PM
Audio-gd C-39MK3 fully balanced dual mono pre-amp Electro3000 Swap Meet 0 9th March 2011 02:45 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
