Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Purifi 1ET400A / Hypex NC500 Input Buffer
Old 2nd April 2020, 06:46 PM   #31
tomchr is online now tomchr  Canada
tomchr's Avatar
I strongly recommend using the pre-crimped leads. You can find them by typing "JST VL" into Digikey's search bar. That should give you this: Jumper Wires, Pre-Crimped Leads | Cable Assemblies | DigiKey
I would buy the 30 cm / 12" ones and cut them in half. If you buy 12 of them, it should be fairly trivial to make an Y harness of an appropriate length.
You can also buy the harness from Hypex.
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old Yesterday, 03:24 PM   #32
mocenigo is offline mocenigo  Germany
WAT, THE BASTARDS! Pre-crimped leads exist? I had to crimp the whole dozen (well I actually only need 10, since the two grounds are connected on the FE02 and also on your boards, and I have only a single ground common to +VP and -VP) myself. Not difficult at all, but still annoying. I am easily annoyed :-)
Old Yesterday, 06:31 PM   #33
tomchr's Avatar
Heh... Yeah... In fact, I generally avoid connectors where I can't get pre-crimped leads.
I have a pretty decent ratcheting crimp tool and have crimped many leads in the past. However, I always have to make do with what I have. The crimping die is never the exact one recommended by the manufacturer, so I double up with a dab of solder, which sorta blows the point of crimping in the first place. Blowing $400 on a die that matches the connector is just not in my budget, so I've come to rely on the pre-crimped leads.
Some of the leads are made by the manufacturer of the connector (Molex MegaFit, for example). Others, I think Digikey actually makes in-house.
Tom
Purifi 1ET400A / Hypex NC500 Input BufferHide this!Advertise here!
Brainstorming Purifi 1et400a amps mocenigo Class D 501 2nd April 2020 12:08 PM
WTD Upgrade input buffer for Hypex nc500 szczemirek Swap Meet 1 25th March 2020 10:56 PM
FS HYPEX nc500 buffer boards Virpi Swap Meet 0 11th February 2020 07:20 AM
Purifi 1ET400A Measurements Diomedian Class D 96 13th January 2020 09:03 AM
Hypex NC500 Buffer Upgrade UltraFidelity Vendor's Bazaar 14 25th November 2019 06:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
