Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Shanti Dual LPS 5V/3A , 5V/1.5A
Old 4th November 2019, 08:36 PM   #931
Nanekiu is offline Nanekiu  Norway
Originally Posted by TimCurtis View Post
It could be a bug in the NAA installer. Post the download link and I'll have a look at it.
Deb file URL for NAA https://www.signalyst.eu/bins/naa/li...0-42_armhf.deb
Old 4th November 2019, 10:12 PM   #932
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
The .deb control file has what appears to be the correct Depends line.
Code:
Depends: libasound2 (>= 1.0.16), libc6 (>= 2.4), libgcc1 (>= 1:3.5), libstdc++6 (>= 5.2), debconf (>= 0.5) | debconf-2.0
moOde 6.3.0 (Raspbian Buster) shows that libstdc++6 is installed.
Code:
pi@rp3:~ $ apt list libstdc++6
Listing... Done
libstdc++6/stable,now 8.3.0-6+rpi1 armhf [installed]
Code:
pi@rp3:~ $ ls /usr/lib/arm-linux-gnueabihf/libstdc*
/usr/lib/arm-linux-gnueabihf/libstdc++.so.6  /usr/lib/arm-linux-gnueabihf/libstdc++.so.6.0.25
I'm not experienced with creating or debugging .deb.files but maybe the HQPlayer maintainer could take a look? I'd be happy to run whatever tests are needed.
-Tim
Old 4th November 2019, 10:43 PM   #933
matthiasw is offline matthiasw  Germany
Code:
Code:
Listing... Done
Code:
-Tim
Do you have an account on Audiophile Style forum?
If yes, then send "Miska" a PM. He replies quickly.
Matt
Old 4th November 2019, 10:52 PM   #934
TimCurtis's Avatar
Maybe a really old one but I don't recall what it is and I barely have enough time to keep up with Moode Forum and diyAudio :-0
I'm thinking that maybe @nanekiu can broker this one. Miska can contact me via tim at moodeaudio dot org if he has time to investigate. I'm not ruling out some sort of bug or breakage in moOde OS with regard to this particular lib but I'm not seeing anything amiss so it's prolly going to take at least two heads to noodle it.
Old 5th November 2019, 08:30 AM   #935
cdsgames is offline cdsgames  Canada
Originally Posted by androa76 View Post
Can be usbridge signature suplied with 8v lipo battery?
5.5V max
Old 6th November 2019, 03:37 PM   #936
randytsuch is offline randytsuch
Originally Posted by cdsgames View Post
Randy , I would sugest to check with diyinhk if there is an upgrade firmware because it seems to me the issue comes from device firmware.
I reached out to diyinhk, but they said to make sure my i2s wires were not too long and also to reinstall windows.
I asked about an updated firmware, but they were silent on that subject.
It really doesn't feel like a xmos firmware issue either, since it works great with a PC running linux (using the hqplayer NAA image loaded on a usb stick).
Since I figured out how to set the clock frequency to eliminate pops at dsd256, I'm fine anyway.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 7th November 2019, 02:04 PM   #937
chris14 is offline chris14
This week , we were very busy testing and improving our products .
Revolution is advancing very well. Nirvana SMPS , we had a breakthrough.
Next week , I will make some announcement and maybe post some pics.
Any Updates?
Old 7th November 2019, 06:57 PM   #938
I managed to fix the issue, I just needed to reflash moode, and lib 6.0+ got detected.
Old 8th November 2019, 01:49 PM   #939
Originally Posted by chris14 View Post
Any Updates?
We were very busy fixing issues on some new PCB , photos and announcements next week .
Old 11th November 2019, 09:24 AM   #940
absolutk is offline absolutk  United States
Is there a simple way to get the Shanti to output 7V? The outer pot can adjust up to 5.8v, and the inner pot doesn’t seem to have an effect on the voltage. A resistor or two perhaps, like the LDOVR modules have?
I know there is headroom because the transformer is 7.5VAC, netting about 10.5V. (I also discovered that despite being set at the factory for 230V, Shanti produced 4.99V in North America :facepalm
Shanti Dual LPS 5V/3A , 5V/1.5AHide this!Advertise here!
Buffer with Dual N-Ch Jfets and Dual Power Supply vdi_nenna Pass Labs 64 22nd April 2019 08:19 PM
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? Junm Swap Meet 0 28th October 2015 04:17 PM
Dual Othorn / Dual modified F215AN Build Log Summary Alethia123 Subwoofers 62 17th September 2014 01:59 PM
50VA Toroidal Transformer Dual Primary 120/120 and Dual Secondary 15/15 KatieandDad Swap Meet 3 11th February 2012 07:26 AM
Dual turntable dual cs741q help needed steelyjoe Analogue Source 0 8th August 2010 04:25 PM
Copyright ©1999-2019 diyAudio
