Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Shanti Dual LPS 5V/3A , 5V/1.5A
Old 16th October 2019, 06:17 PM   #751
hoqpus is offline hoqpus
Originally Posted by cdsgames View Post
Smartphone charger..how many A ?
Have you chosen the USB output ?
Enough. Oneplus charger 5V / (up to) 4A
Moode 6.3.0 is now installed on my RPi. I will now put this sd in the USBridge to check if it's on the SW
With my RPi the display only works during start up -.-
Now I'm out of ideas
Booted my RPi with the sd card from the USBridge
-> no sound, but display is working like on the Bridge.
-> all issues seem to be connected to SW
Booted USBridge with RPi sd card
-> finally sound, no display
-> no the sw issue in the USBridge Image needs to be sorted out
Old 16th October 2019, 06:29 PM   #752
cdsgames is offline cdsgames  Canada
Ladies and gents,
I am unable to turn off Revolution Dac. I have listened to Take 5 , Destiny Child Survivor , Los Panchos " Sin Ti" and last to Issac Stern (ave maria sounds wonderful)
I never had a DAC with less hi frequency grating (to ears). There is absolutely no "out of band noise" called also "fatiguing sound"
Its musical , its full of detail , and its the NOT bright (I know why ess sound bright , I am able to see the 900Khz spike and I figured a way to reduce it) . In a way its closer to Boss than Katana , while keeping all the microdetail
Still I am using rev Dac + Usbridge Sig and Shanti LPS feeding both. Earthing is done using star ground (Usbridge Sig is connected to Shanti earth , Rev earth is connected to same point).
My best explanation is that absence of hi frequency sound seems to be relaxing alowing to enjoy the music.
Wifey was able (on 3 songs , blind testing) to pick up Rev at 100% times (yeah I know not very scientific)
More details in the days to come.
Old 16th October 2019, 06:33 PM   #753
Send me a PM with your email and I will get you in contact with Sudeep. So far we solved 3 issues today
Usualy its in the setting of customers (not that I think that necessarily your issue, just saying thats how we solved them)
Old 16th October 2019, 06:51 PM   #754
matthiasw is offline matthiasw  Germany
Ladies and gents,
Which OS for SIG did you use for this listening?
Matt
Old 16th October 2019, 06:53 PM   #755
I cross checked by installing Moode 6.3.0 on my RPi. And then exchanging the sd cards. On my RPi sound is working but the display for some reason not.
-> now the sw issue in the USBridge Image needs to be sorted out
Old 16th October 2019, 06:56 PM   #756
I have sent email to Sudeep
If I understand this correctly on both RPI and Usbridge Sig with Moode 6.3.0 you get sound now but no display ?
Old 16th October 2019, 06:58 PM   #757
Thanks will keep you up to date
Old 16th October 2019, 07:02 PM   #758
Matt
Moode
Old 16th October 2019, 07:08 PM   #759
I am not sure if Tim is around,,,will ping him since it seems to me its the same issue on RPI/Usbridge Sig
Old 16th October 2019, 07:14 PM   #760
Shall I just reset all settings to default?
Is there anything significant that you are changing?
Shanti Dual LPS 5V/3A , 5V/1.5AHide this!Advertise here!
Buffer with Dual N-Ch Jfets and Dual Power Supply vdi_nenna Pass Labs 64 22nd April 2019 07:19 PM
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? Junm Swap Meet 0 28th October 2015 03:17 PM
Dual Othorn / Dual modified F215AN Build Log Summary Alethia123 Subwoofers 62 17th September 2014 12:59 PM
50VA Toroidal Transformer Dual Primary 120/120 and Dual Secondary 15/15 KatieandDad Swap Meet 3 11th February 2012 06:26 AM
Dual turntable dual cs741q help needed steelyjoe Analogue Source 0 8th August 2010 03:25 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
