Shanti Dual LPS 5V/3A , 5V/1.5A
I'm very interested in the Revolution DAc that will soon come on the market. A good complement to the USBridge Sig/shanti couple. My only concern is its uUSB port which will force me to change my USB cable. I've been looking for a good USB audio cable with a uUSB connector but I can't find it.
Maybe Allo or the community would have something to advise?
Also, can someone confirm that the Rev Dac can be powered by the 5V/1A line of the Shanti?
Thank you.
Is there any difference between using an SD card or eMMC on the USBridge Sig ?
I have one on order from Audiophonics, does it come supplied with an OS card, no option was listed, though on your website it is ?
Am I right in thinking that adding a ground link between the USBridge Sig and the Shanti PSU which is also on order lowers the noise floor ?
I shall be only using one USB port for a 1TB SSD input which of the USB's should I use ?
Thanks in advance.
