Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Vendor's Bazaar Commercial Vendors large & small hawking their wares |
Thread Tools |
#2111 |
Power amplifier . Input sensitivity depends on gain (and if balanced/single ended)
For the moment I have 0db , 6db and 9db |
#2112 |
Hi, I am going to buy Allo USBridge Sig with Allo DigiOne Sig (combo in one case), and I would like to know if Moode OS 7.1.0 is fully supported? I would like to download the generic OS image from moodeaudio.org, put it to SD card ... or shoud I download image from allo site? Is there a difference?
I have also noticed the is a separate power input in the combo case for DigiOne Sig clean side. Which power plug should I use? Is it DC 5.5 X 2.1mm Input? |
#2113 |
Hi Sojer
yes you can use the Moode image direct for USBridge. Yes input 5.5x2.1mm for Digione clean side |
#2114 |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Buffer with Dual N-Ch Jfets and Dual Power Supply | vdi_nenna | Pass Labs | 64 | 22nd April 2019 07:19 PM |
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? | Junm | Swap Meet | 0 | 28th October 2015 03:17 PM |
Dual Othorn / Dual modified F215AN Build Log Summary | Alethia123 | Subwoofers | 62 | 17th September 2014 12:59 PM |
50VA Toroidal Transformer Dual Primary 120/120 and Dual Secondary 15/15 | KatieandDad | Swap Meet | 3 | 11th February 2012 06:26 AM |
Dual turntable dual cs741q help needed | steelyjoe | Analogue Source | 0 | 8th August 2010 03:25 PM |
New To Site? | Need Help? |
