Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Shanti Dual LPS 5V/3A , 5V/1.5A
Thread Tools
Old 13th January 2021, 07:16 PM   #1971
ed linssen is offline ed linssen  Netherlands
Default amp and Boss 2
And the Boss2?
Old 13th January 2021, 07:32 PM   #1972
stretchneck is offline stretchneck  United Kingdom
Mono block please!!!
Old 14th January 2021, 10:26 AM   #1973
cdsgames is offline cdsgames  Canada
Boss2 , should be in stock in 10 days or less.
AMP is delayed , we expect the new PCB at end of Jan. 24H after I will post the new test data.
Old 14th January 2021, 10:41 AM   #1974
Thanks for the update - will it have integral SMPS?
Photos would be good once ready :-)
Old 14th January 2021, 11:02 AM   #1975
Yes LLC SMPS for each channel sold in a ALU box
We might release as PCB only for DIY where you can buy only one SMPS (275W continuous ) for 2 channels
Old 14th January 2021, 01:48 PM   #1976
chris14 is offline chris14
Have you evaluated the Amp in this configuration, 2 channel stereo ? How does performance compare to the mono blocks.
Old 14th January 2021, 02:12 PM   #1977
The only evaluation was by AP and Spectrum analyzer . We do see some lesser specs but nothing too dramatic . Still be aware that since we are using aircore inductors , keep the 2 modules at least 15cm apart (will give more details on it once we release)
Old 14th January 2021, 05:35 PM   #1978
misterdog is offline misterdog  United Kingdom
Old 15th January 2021, 03:20 PM   #1979
pdb is offline pdb  Denmark
pdb's Avatar
You could buy 2 DIY sets and then have 4 boards and 2 PSUs wired up with lateral or horizontal biamping.
Old 15th January 2021, 04:01 PM   #1980
Does the aluminum case have an effect on the inductance of the aircores, and have you tested the cased boards?
Shanti Dual LPS 5V/3A , 5V/1.5AHide this!Advertise here!
Thread Tools
Buffer with Dual N-Ch Jfets and Dual Power Supply vdi_nenna Pass Labs 64 22nd April 2019 08:19 PM
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? Junm Swap Meet 0 28th October 2015 04:17 PM
Dual Othorn / Dual modified F215AN Build Log Summary Alethia123 Subwoofers 62 17th September 2014 01:59 PM
50VA Toroidal Transformer Dual Primary 120/120 and Dual Secondary 15/15 KatieandDad Swap Meet 3 11th February 2012 07:26 AM
Dual turntable dual cs741q help needed steelyjoe Analogue Source 0 8th August 2010 04:25 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
