Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Shanti Dual LPS 5V/3A , 5V/1.5A
Old 3rd July 2020, 01:43 PM   #1591
cdsgames is offline cdsgames  Canada
Send me an email and I will look into it.
Does anyone know what type of offset you can have on XLR and sound quality impact of the offset ?
Old 3rd July 2020, 02:52 PM   #1592
Markw4 is online now Markw4  United States
Depends on the common mode rejection performance of the differential receiver. For a transformer the permissible offset voltage can be very high. Active differential line receiver circuits are all different, and in the case of dacs it may also depend if low level RF is present along with the offset (since both factors can increase, say, opamp, distortion somewhat).
Old 3rd July 2020, 03:58 PM   #1593
SonofThor is offline SonofThor  United Kingdom
No.
Be interesting to hear your thoughts on this. Received mine today - using it with Shanti/USB Sig and it's replaced a Kali/Piano 2.1. Had it warming up all day and just started listening. Initial impression are very good
Old 3rd July 2020, 05:47 PM   #1594
zzt231gr is offline zzt231gr  Greece
No,it is not bright...The stock SMPS sounds very good!You can read countless reviews stating that it is neutral.
Old 3rd July 2020, 09:35 PM   #1595
reelben is offline reelben  Netherlands
God this dac is beautiful for the money.
I have listen a lot of audio in my life, for so much money
This is a happy match, everything can I play for no stress.
Before this a test a Cambridge, a ifi, a chord, ayre , so much more... always I go back to search for something ..what I can not set on paper.
I want can play everything without stress or how can I it good write in words here
Everything must grab me in the music.
So that you forget everything in your setting.
Now this is it what the evolution is doing, clap your hands or feet and forget what you listen to. (hardware)
Music nothing but sound so it goes now.
Now I go dance and stamp with my feet
Wow this is amazing.
Old 4th July 2020, 12:44 PM   #1596
Nanekiu is offline Nanekiu  Norway
So how would you recommend connecting the ground cables between etc Uxbridge sig, Shanti, and revolution dac,
1: 1 ground cable to Usbridge from rev dac, then another ground cable from usbridge to Shanti
2. One ground cable from usbridge to shanti, then another groundcable from rev dac to shanti.
3. On
Old 4th July 2020, 03:00 PM   #1597
3. On
This is in the manual CDSGames posted earlier, post #1585
Old 4th July 2020, 04:45 PM   #1598
Star connection. Rev to Shanti. Usbridge to Shanti. You can see the diagram on latest manual I posted.
Old 5th July 2020, 10:30 AM   #1599
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Thumbs up Review
Hello cdsgames,
after a few days of burn-in, I would like to tell you and the forum my impressions.
The jump of the SQ from Boss V1.2 to Rev. is already very clear. The whole width and depth of the stage increases noticeably and the precision, also and especially in the bass range is great. I quickly realize that my Yamaha AST-S1 has reached a limit here to display the full quality of the Rev.
You and the whole Allo Team are to blame for the fact that, I retired the Yamaha speakers and amplifier yesterday and bought a couple of new B&W 706 S2.
So I was able to reactivate my homemade nxV300 amplifier, which until then had had no job.
The result knocked me off my chair. Simply breathtaking what the Rev. does with this combination and with the SSLV 1.3 Shunt PS.
No matter if Jazz with Oscar Peterso Trio, Diana Krall and Maceo Parker, Instrumental with Eva Cassidy and Nils Lofgen, Blues with John Lee Hooker, Pop/Rock with Pink Floyd, Peter Gabriel and Phil Collins up to classical music...
Unbelievable for this price range!
In the coming days there will be some fine-tuning with the settings.
Thanks a lot for this great DAC.
Best Regards
Oliver
F5 - SSLV 1.3 Ultra BiB
Old 5th July 2020, 01:01 PM   #1600
pdb is offline pdb  Denmark
pdb's Avatar
Originally Posted by dvb projekt View Post
... No matter if Jazz with Oscar Peterso Trio, Diana Krall and Maceo Parker, Instrumental with Eva Cassidy and Nils Lofgen, Blues with John Lee Hooker, Pop/Rock with Pink Floyd, Peter Gabriel and Phil Collins up to classical music...
Unbelievable for this price range! ...
Thanks for your review. Btw the nxv300 link did not work but gave a 403 error. Thanks again --- Per
Shanti Dual LPS 5V/3A , 5V/1.5AHide this!Advertise here!
Buffer with Dual N-Ch Jfets and Dual Power Supply vdi_nenna Pass Labs 64 22nd April 2019 07:19 PM
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? Junm Swap Meet 0 28th October 2015 03:17 PM
Dual Othorn / Dual modified F215AN Build Log Summary Alethia123 Subwoofers 62 17th September 2014 12:59 PM
50VA Toroidal Transformer Dual Primary 120/120 and Dual Secondary 15/15 KatieandDad Swap Meet 3 11th February 2012 06:26 AM
Dual turntable dual cs741q help needed steelyjoe Analogue Source 0 8th August 2010 03:25 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
