Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
OPA1656: High-Performance CMOS Audio Op Amp
Old 12th February 2020, 11:13 PM   #161
Joachim Gerhard is online now Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I build a headphone amplifier prototype with it without buffer. I have not measured it so far.
File Type: jpg A3866EA4-6E19-49B4-829D-B700C8E31E10.jpg (676.5 KB, 224 views)
Old 12th February 2020, 11:21 PM   #162
I drive a mechanically modified Meze 99 Classics with it. It played much louder then the Meze can stand. I can easy reach scull resonance and beyond.
File Type: png 1B2170AB-C841-4069-8D25-A7EE36026BDB.png (854.2 KB, 220 views)
File Type: jpg 2188BA27-30ED-47D1-AA14-AF060C38DE2B.jpg (132.6 KB, 226 views)
Old 12th February 2020, 11:49 PM   #163
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
Azul headphone amp (BAF 2019) uses an OPA1611 + LH0033 composite. It'll deliver 75mA RMS into a 32 ohm load; that is 180 mW which is quite a bit greater than the rated maximum shown in post #162.
But after (sighted) opamp rolling, I discovered I prefer the sonics with LT1122 + LH0033. The late, great George Erdi knew what he was doing when he designed the LT1122.
_
Old 15th February 2020, 01:03 AM   #164
chris719 is offline chris719  United States
_
I'm not sure what redeeming qualities the LT1122 has these days, from an objective standpoint. It's not particularly fast and it's noisy. It seems like it's blown away in every metric by OPA810 and OPA828.
Old 15th February 2020, 01:24 AM   #165
johnc124 is offline johnc124  United States
I love that case. I'm a huge pan of walnut (or other types of wood) side panels.
Product Line Manager - TI High Speed Amplifiers
OPA1637: New Fully-Differential Amplifier for Audio
Old 15th February 2020, 01:52 AM   #166
Yes, it is beautiful, made by a local craftsman.
Old 15th February 2020, 02:17 AM   #167
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Given its age, its cheap on the secondary market. Around $0.30 a pop. AD744 is cheaper still though and at half the supply current.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 15th February 2020, 07:09 AM   #168
PoweRex is offline PoweRex  France
I mean, even -60dB of any distortion should not be audible but why sound components different? Are we measuring the wrong thing ? Can sound quality be quantified per se ?
Of course that THD is not so important to the human ear/brain tandem : the last step in the signal reproduction chain is the loudspeaker itself showing more than several percent of THD in the best case ! So how would you be able to distinguish 0.0001% from 0.1% of THD in an amplifier feeding a loudspeaker ? As a comparison, we are much more sensible to IMD and even much more to phase distortion leading to jitter in digital domain (timing errors) and to group delay disorder in analog domain. In fact, we should always consider the time domain for dynamic signals (like music) and not only the harmonic domain for static measurement signals...
Old 16th February 2020, 04:23 PM   #169
HpW is offline HpW
Back to the main OPA1656 thread...
Is there any Spice model to simulate the channel cross talk of this dual OP-AMP?
Originally Posted by johnc124 View Post
Single OPA1655: They're working on it! Stay tuned.
Do you (TI) plan to provide any metal TO-99 case too?
Hp
FFT Analyzer & Generator at www.hpw-works.com
Old 16th February 2020, 08:07 PM   #170
Hp
Spice models almost never include crosstalk and most often the model for the single/dual/quad versions of an op amp are the same unless there is a significant parametric difference between the variants. You could probably duplicate the effects with a passive component network outside of the op amp macromodel.
At audio frequencies I normally see the internal crosstalk of an op amp totally swamped by power supply effects or the impedance of the ground plane on the PCB. On headphone amplifiers its always the shared ground contact in the headphone jack which usually limits crosstalk between the left and right channels to about -70dB. The good thing is that you don't listen to speakers at home with a wall running down the center of your room right up to your face...
It's not really my call, but I can say with almost absolute certainty that there will not be a TO-99 package of this device. The economics of that would not make any sense. The only way I could see that happening is if an outside company wanted to make that product, we'd love to sell them bare die and let them do the packaging.
OPA1656: High-Performance CMOS Audio Op AmpHide this!Advertise here!
SAR ADC for high performance audio ADC project [LTC2380-24] Frex Equipment & Tools 236 25th April 2019 03:59 PM
High performance subwoofer filter circuit(low pass) to your audio amp rrbadrike Analog Line Level 3 12th January 2017 03:06 PM
High performance audio opamps that are currently in production Fusion916 Solid State 3 8th February 2016 08:06 PM
Profi drivers in High End audio cabinets - for the ultimate performance Bojan Hajdinjak Multi-Way 13 2nd June 2004 11:03 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
