Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Output transformers for DACs
Old 15th May 2019, 01:37 AM   #71
thuanth43 is offline thuanth43  Viet Nam
Do you offer step up input transformers? Ratio 1:10, 500:50k.
Old 15th May 2019, 06:36 PM   #72
bisesik is offline bisesik  Kazakhstan
angcl, pair means two units (for stereo), yes
Old 15th May 2019, 06:42 PM   #73
thuanth43, not now, sorry
Old 21st May 2019, 01:08 PM   #74
laserscrape is offline laserscrape
Can a trafo with a single secondary drive a differential amp input when the primary has a differential input with no ground reference, like with Sabre or AKM?
I can understand the need for 2+2/0.5+0.5 to get a differential output when the primary is referenced to ground (like PCM1792 or single ended DAC), but it seems like you shouldn't need it for the 9038 .
BTW I am using your trafo with TDA1387 NOS DAC at the moment.
The trafo is a much better match for this NOS DAC than the 9038Pro DAC, it sounds better than any delta sigma DAC Ive heard too.
Old 21st May 2019, 03:02 PM   #75
There is no relation between both the primary source + coil (no matter if it balanced or single ended signal applied) and the secondary coil\coils, because they are galvanically isolated. I have version 1:2+2 too. If your amplifier can handle sound without ground reference then yes, you can use only one secondary coil.
Interesting Is there any additional info regarding signal level and frequency response \ quality on LF when use with 1387? One 1387 chip or parallel circuit?
Old 21st May 2019, 07:10 PM   #76
thanks, although I still need to build the 2nd HP amp to use 2 of them in a balanced configuration I can still test 1 amp in 'mono' balanced and see how it works first.
I have only messed around briefly with TDA so far, there was around 8 of them in parallel and output level was much higher than necessary.
Considering the cost you can stack as many of these chips in parallel as you like, but im not noticing much real benefit to it ... others even reported negative effects to SQ for some DACs.
I guess its down to how well the chips are matched.
Old 22nd May 2019, 04:48 PM   #77
Aslong as the DAC and amp ground are connected, the single secondary winding of 1:4 trafo is working properly when connected to the balanced amp input. This is with the primary connected single-ended to TDA1387 aswell.
Old 23rd May 2019, 03:25 AM   #78
Do you mean this circuit?
Or this?
Old 23rd May 2019, 08:01 AM   #79
the first circuit, yes. (plus the I/V resistor)
Output transformers for DACsHide this!Advertise here!
PC based I2S Output for compatible DACs Vortex Digital Line Level 1 5th May 2018 07:37 PM
Zapfilter2 and current-output dacs Glenn2 Digital Line Level 5 31st October 2016 07:36 AM
D2A aragon dac with blowed output stage after the dacs... inertial Solid State 0 8th July 2013 04:04 PM
Differential output DACs, can I use only one output. oon_the_kid Digital Line Level 14 4th July 2011 02:09 AM
any info. anywhere on output stages for dacs? lt cdr data Digital Source 3 21st May 2005 04:18 AM
Copyright ©1999-2019 diyAudio
