Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Output transformers for DACs
Thread Tools
Old 6th August 2020, 02:41 PM   #451
Myint67 is offline Myint67  Singapore
ivan ,
That great
myint
Old 6th August 2020, 04:58 PM   #452
Vunce is offline Vunce  United States
This is indeed good news, I’m interested as well.
Old 10th August 2020, 05:56 AM   #453
Default 9038 pro
dear Ivan,
transformer (attach) can use 9028 & 9038 pro dac ?
one of diy munber selling transformer for ian pcb (9028)
i would like to use quan hao pro dac & your IV out put pcb board.
best regards
myint
File Type: jpeg F2EC637F-4E9C-47A8-B291-276B7F7990EA.jpeg (188.3 KB, 637 views)
File Type: jpeg 51A9717B-8FD1-4CD3-B120-37ADEE0F28FE.jpeg (242.0 KB, 624 views)
File Type: jpeg 47E7A3D8-7380-481C-9E54-1741AD09C6FA.jpeg (15.6 KB, 626 views)
Old 11th August 2020, 09:27 PM   #454
bisesik is offline bisesik  Kazakhstan
Sure, you can use it for 9028 and 9038 pro DACs, but it if it will be the last version of 1:7 turns ratio.
Ivan
Old 12th August 2020, 05:39 PM   #455
chromenuts is offline chromenuts  United States
Hi bisesik
I do not have the experience to understand or implement differential mode. If it entails a balanced output arrangement, then that is not what I am after. I need a single ended output as you mentioned.
I was under the impression I could still maintain SE output while implementing a dual mono configuration by using a second D3 board and TDA1541A.
I thought Ryan already had a set of your transformers. I guess I misunderstood and he had simply tried another type of transformer IV stage and had ordered a set of transformers from you.
Ryan designed his D3 boards with a IV resistor and DC offset compensation circuitry to null the offset on board. I was hoping that meant the DC offset issue was irrelevant.
Please excuse my ignorance regarding these issues.
I would be interested in any transformer IV stage solution you were able to come up with that would allow me to avoid further complexity in this first DAC build of mine.
Old 14th August 2020, 12:08 PM   #456
chromenuts,
Differential mode of any DAC connection relates to its performance, DC-offset cancellation in case of TDA1541 is a bonus. Balanced or SE output is a part of the secondary coils and independent from DAC connection mode. In any case as I wrote, I can offer two versions (or one versatile) for regular or for differential mode of TDA1541 connection.
Ivan
Old 14th August 2020, 01:56 PM   #457
beardman is offline beardman  Denmark
time to tell how the bisesik trafo play
my dac is JLsound AK4493,,with clock board and usb input
i have used 3 different output board
JLsound output board with Newclassd discrete opamp---absolute not bad
Mirand discrete output board---a little bit better
and now bisesik output trafo---by far the best
sound from the trafo..strong, dynamic,open,,nice for the ear,,lovely sound
i use the muting from JLsound output board,,so i have no click from the dac
well done bisesik
Best Bjarne
Old 29th August 2020, 10:10 PM   #458
lemon is offline lemon  Greece
What type trafo are you used with 4493?
1:1 SE or 1:1 balanced?
Old 30th August 2020, 06:58 AM   #459
I use 1:1 SE to my 4P1L preamp
Old 17th September 2020, 10:43 AM   #460
potstip is offline potstip  Turkey
Hello Ivan;
4493 needs Low pass filter after dac chip. With output transformer are we eliminate this? Or still we need it before or after transformer?
Output transformers for DACsHide this!Advertise here!
Thread Tools
PC based I2S Output for compatible DACs Vortex Digital Line Level 1 5th May 2018 08:37 PM
Zapfilter2 and current-output dacs Glenn2 Digital Line Level 5 31st October 2016 08:36 AM
D2A aragon dac with blowed output stage after the dacs... inertial Solid State 0 8th July 2013 05:04 PM
Differential output DACs, can I use only one output. oon_the_kid Digital Line Level 14 4th July 2011 03:09 AM
any info. anywhere on output stages for dacs? lt cdr data Digital Source 3 21st May 2005 05:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
