Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Output transformers for DACs
Thread Tools
Old 6th July 2020, 11:35 AM   #441
bisesik is offline bisesik  Kazakhstan
Originally Posted by angcl View Post
any update ?
I thinks I just want the trans, no need the PCB to save cost , this is for twisted Twisted Pear Audio ,Buffalo-IIIse .
Have PMed to you.
Ivan
Old 7th July 2020, 07:38 AM   #442
yunyun is offline yunyun
how to buy this board ? I am keen .
GitHub - iancanada/DocumentDownload: Download documents of Ian's products
Old 7th July 2020, 08:10 AM   #443
bisesik,
For the newly designed PCB, can you draw a picture similar to the one below for beginners?
Old 8th July 2020, 05:08 AM   #444
Originally Posted by yunyun View Post
bisesik,
Attachment 858685
Exact the same connection
Ivan
Old 8th July 2020, 05:11 AM   #445
But there are more pin for beginners...
Can the XLR and SE outputs of the PCB use terminals? Like IVY III BALANCED LINESTAGE.
Old 8th July 2020, 09:29 AM   #446
Rows in 2x5 headers are connected in parallel (just for better header fixation on the board). All the other jumpers are pre-installed for correct functioning.
Regarding terminals. I suppose it is possible to use terminals instead of XLRs\RCAs using existing thruhole pads, somehow this way:
based on that terminals:
Blocked
But definitely it is possible to correct PCB for regular terminals at require in the next orders (will take extra time of course for manufacturing).
Ivan
Old 4th August 2020, 06:35 PM   #447
chromenuts is online now chromenuts  United States
I am working on a TDA1541A DAC based on Ryanís D3 boards.
The first version is a single D3/TDA1541A. I will simply be trying it with a iv resistor to see how it works with my system. However, Iíve already put things in motion to try dual/mono TDA1541A in the future.
Ryan already purchased a set of your transformers for use with his boards and gave a good review.
If I want/need a pair of your iv transformers...do they have to be wound specifically for either a single TDA1541A or the dual/mono?...or is it possible to use the same transformers with either arrangement?
Also, can you post the dimensions of your current PCB for the transformers so I can make sure I have space allotted in my case?
Old 4th August 2020, 06:47 PM   #448
Myint67 is offline Myint67  Singapore
Default D3
Hi ,
I also looking for IV transformer(1:4 )for dual dual mono design using D3 TDA/1541 A.
pls check attach.
File Type: jpeg A88634FE-41EA-4E21-BC7D-44E1BA9323B6.jpeg (105.1 KB, 433 views)
Old 5th August 2020, 08:01 PM   #449
chromenuts, Myint67
There is a problem with TDA1541 in original SE connection mode is caused by the DC-offset presented at the output. I can make suitable transformer in general, but the special type of the core is needed then, which I haven't now (and do not want to order a batch due to low demand compared to other non-DC-offsetted DACs). There is another way to solve the offset, to make the additional compensation coil. First, it is more expensive to manufacture, but it is more complicated for the end user in addition as the separate power source will be needed.
Taking into account all aboved, I prefer to avoid DC-offsetted DACs. But the differential mode of 1541' connection allows to use my transformers in a regular way - all you need is just to use center tap at GND (two primary coils) - two DC-offsets should be selfcompensated then and cores will not be oversaturated.
Lets wait for Ryan's report (transformers are still on the way to him)...
Ivan
Old 6th August 2020, 12:52 PM   #450
chrome nuts, Myint 67...
Thanks to your posts, I have renewed my "investigation" on the TDA1541A (which is inside my Marantz CD65 CDP), which was paused during the last 2 years many times in attempts to find the needed approach of winding. As a result just today I have found the way to make transformers, suitable for TDA1541 in SE mode without need of DC-compensation.
FR 20-20k: -0.3 / -0.8 dB (1.8Vp-p)
Ivan
Output transformers for DACsHide this!Advertise here!
Thread Tools
PC based I2S Output for compatible DACs Vortex Digital Line Level 1 5th May 2018 08:37 PM
Zapfilter2 and current-output dacs Glenn2 Digital Line Level 5 31st October 2016 08:36 AM
D2A aragon dac with blowed output stage after the dacs... inertial Solid State 0 8th July 2013 05:04 PM
Differential output DACs, can I use only one output. oon_the_kid Digital Line Level 14 4th July 2011 03:09 AM
any info. anywhere on output stages for dacs? lt cdr data Digital Source 3 21st May 2005 05:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
