Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Vendor's Bazaar Commercial Vendors large & small hawking their wares |
Thread Tools |
#431 |
Output transformers for DACs
Update.
Another step-up version of transformer have been developed. Turns ratio: 1:6+6+6 (1:6 or 1:12 or 1:18) Frequency response (source 40 ohm, 10 K ohm load, 1:18): -3dB points: 2Hz & 115kHz -1dB points: 3Hz & 75kHz Application: impedance matching for moving coil phono cartridges Price: $205 for pair
Ivan Last edited by bisesik; 30th June 2020 at 08:47 AM. |
#432 |
Hi bisesik,
Would it be possible to make a pair of transformers for the AKM4499, please? Depending on possibilities, I may use it to drive this circuit: http://itsonlyaudio.com/ultranalog/c...ancer2_3a5.pdf -Raja |
#433 | |
#434 |
Hi bisesik,
I need a output trans for my Twisted Pear Audio ,Buffalo-IIIse Pro ES9038, what is the price now ? what is the shipping cost to Singapore ? thanks With regards Angcl |
#435 | |
Yes sure.
Ivan |
#436 | |
Price for finished i/v board (like showned here Output transformers for DACs ) is $240. Regarding shipping to Singapore. As I posted previously unfortunatelly there is still no airmail-service within my national post company and many directions are closed due to flights absence. That is why the one only possible way to send it to you right now is via courier-post like FedEx\DHL\UPS. Prices are quite high unfortunatelly ~$100. I am still in the process of finding another more accessible shipment way...
Ivan |
#437 | |
#438 | |
Very useful pdf schematics. The female pins accepting are the same as before or they are differente? |
#439 | |
Sure, forgot about pinout: pin allocation.jpg
Ivan |
#440 |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
PC based I2S Output for compatible DACs | Vortex | Digital Line Level | 1 | 5th May 2018 08:37 PM |
Zapfilter2 and current-output dacs | Glenn2 | Digital Line Level | 5 | 31st October 2016 08:36 AM |
D2A aragon dac with blowed output stage after the dacs... | inertial | Solid State | 0 | 8th July 2013 05:04 PM |
Differential output DACs, can I use only one output. | oon_the_kid | Digital Line Level | 14 | 4th July 2011 03:09 AM |
any info. anywhere on output stages for dacs? | lt cdr data | Digital Source | 3 | 21st May 2005 05:18 AM |
New To Site? | Need Help? |
