Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Output transformers for DACs
Old 18th November 2019, 09:39 PM   #301
randytsuch is offline randytsuch
Originally Posted by TioFrancotirador View Post
@bisesik
Ivan does you trafo for DSC will also work with this new project ?
STAR Pure DSD DAC-Signalyst New
I think the difference is on the front end. Quanghao/Andrea added the ct7302 to generate the dsd stream.
Or did I miss something?
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 18th November 2019, 09:46 PM   #302
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Yes, that's what I see too. The only variation on the output seems to be the inclusion of a relay to enable single-ended or balanced output to be selectable.
Old 19th November 2019, 03:59 AM   #303
yunyun is offline yunyun
Originally Posted by lindamar View Post
Thank you bisesik !
I will pm you then. I was not hoping a price like the chineese ones, don’t worry
In fact, there are more expensive transformers on Taobao. It uses 0.06mm 5N OCC and a 12.5~24mm thick core.
Primary resistance: ~ 1340 Ohms
Primary Inductance: ~ 1100-1200 Henry
FR 10Hz ~ 100KHz -0.2DB.
2 coils with PCB and Shield: 71~242 USD
5N单晶铜OCC漆包线绕制的美国Jensen战神10K:10K音频变压器复刻版
Old 19th November 2019, 01:48 PM   #304
casshan is offline casshan  Hong Kong
Originally Posted by paoloilpizzo View Post
I recognise most of the components in the picture but not the board under the tower raspi + DAC + transformers
What is it?
It is Neutron Star 2 Reference Clock
Old 19th November 2019, 10:53 PM   #305
clay-speakers is offline clay-speakers  Australia
I have just tried bisesik's 0.5+0.5:4 PELSHO transformers with a new AK4499
DAC I am developing.
The results were very impressive.
I achieved 2v rms out using a 1k8 resistor across the secondary winding.
The DAC is configured in the register's for dual mono & I use the dual primary windings
to mix each pair of outputs from the AK4499.
Old 19th November 2019, 11:09 PM   #306
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
@clay-speakers : will you have this AK4499 DAC for sale as DIY project?
Do
PREAMPs : AMB α10 + USSPA | LDR3x + USSPA | AMPs: AMB β24 | USSA5 | TGM8 | VZ Audio NS OPS | FC-100 | Modulus-686 |
DACs : Mirand AK4490 + Discrete Output | Ian Dual ES9038K2M | Speakers : Troels Gravesen ATS-4 | Sagwee LT V3 |
Old 19th November 2019, 11:42 PM   #307
paoloilpizzo is offline paoloilpizzo  Italy
paoloilpizzo's Avatar
Wow !!!
In which way did you connected the clock to fifopi ? Can you post some photos?
Old 20th November 2019, 12:03 AM   #308
Do - I normally just build finished units but I have been thinking about DIY/shortform kits
lately so I will give it some thought.
Old 20th November 2019, 12:06 AM   #309
pinnocchio's Avatar
That would be amazing!
Old 20th November 2019, 08:22 AM   #310
bisesik is offline bisesik  Kazakhstan
Here are comparative measurements with stock transformers. Nothing have changed during measurements - conditions are the same for both measurements.
Warning! This level of -10dB (0.62Vrms) was chosen due to highest SNR possible in my particular setup. I do not pretending for the best absolute measurings or exclusivity of my particular stand - it was just to compare transformers in the same conditions. Relation of THDs will be saved at any output level.
Output transformers for DACsHide this!Advertise here!
PC based I2S Output for compatible DACs Vortex Digital Line Level 1 5th May 2018 08:37 PM
Zapfilter2 and current-output dacs Glenn2 Digital Line Level 5 31st October 2016 08:36 AM
D2A aragon dac with blowed output stage after the dacs... inertial Solid State 0 8th July 2013 05:04 PM
Differential output DACs, can I use only one output. oon_the_kid Digital Line Level 14 4th July 2011 03:09 AM
any info. anywhere on output stages for dacs? lt cdr data Digital Source 3 21st May 2005 05:18 AM
Copyright ©1999-2019 diyAudio
