Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Output transformers for DACs
Old 10th December 2018, 10:12 AM   #21
bisesik is offline bisesik  Kazakhstan
Originally Posted by analog_sa View Post
Whether the loading resistor is applied to the primary or secondary the effective load seen at the dac output is way too high for any reasonable voltage compliance.
"too high" compared to what?
Is it to act as a low pass?
including
Old 8th March 2019, 01:06 PM   #22
dubai2000 is offline dubai2000  Europe
I have been using those transformers for a while in an ancient Sony CDP that contains a CXD2552Q2 D/A chip - I know, old technology - but I have always liked the big soundstage created by that player. Once I started tinkering with my gear I tried a variety of CDP mods - different capacitors, bypassing the output stage after the opamps - and, as a matter of course, different opamps - all the way to discrete ones (manufactured by two different companies).
Well, to cut a long story short - I was introduced to Ivan's transformers in a friend's project - and as it takes a bit longer than expected to replicate it - I decided to use the transformers in the above mentioned CDP - and - there is no way that I shall ever go back to any opamp - the only way that comes to mind to describe what the transformers have done to the music is - taking away any digital artifacts (for the lack of a better word). CDs - especially well-recorded ones - sound simply more natural without any digital "harshness" - and those that are less well recorded? Well, they sound the way they are, but still a lot better than before - and some even far less thin that I had always believed. So, yes, I am a very happy customer and the next step is going to be getting those trannies that can be used with a TDA1541 player.
Old 8th March 2019, 04:41 PM   #23
androa76 is online now androa76  Slovenia
Excellent.
In a few days i will try them with accu powered ak4495 dac. To completely eliminate power supply influence and hear what this transformers brings instead of all sort of output stages that i have tried till now.
Old 15th March 2019, 08:39 AM   #24
laserscrape is offline laserscrape
Can one transformer be configured to provide balanced or single ended output or do you have to choose?
Old 15th March 2019, 09:21 AM   #25
Sure, I can make 1:0.5+0.5 or 0.5+0.5:0.5+0.5 (if the DAC have differential output and center point is needed) version of turns ratio for your choice. You will connect coils different ways to provide SE or BAL outputs. It is extra 10USD to the cost of standard (1:1) version.
dubai2000 Simple and understandable Thank you!
Old 15th March 2019, 09:46 AM   #26
ok, so for 9038Pro 0.5+0.5:2+2 would be the right choice?
Old 15th March 2019, 10:16 AM   #27
I have not tried 9038pro, but for 9018s I am using 1:4 in SE version. For the BAL output there will be 2+2, but for the primary coil you can use 0.5+0.5 or 1 for your choice. So yes 0.5+0.5:2+2 is OK to use anyway.
Old 15th March 2019, 10:32 AM   #28
In case of ES90x8 chips there is no need to use grounded center point between + and - of the signal. Moreover my expiriences says me that avoiding tighting somehow to ground of the output signal from DAC (if it is possible) is better for SQ. There are some DACs that have + and - of the signal with respect to the ground (like PCM1792) - and in that case there will be no sound at all, untill you not connected to the ground. Say if you can avoid summing stage then no need to split the load. So in case of ES90x8 or AK449x - there is no need to "watch the ground". You can but not necessary.
Old 15th March 2019, 10:46 AM   #29
ah i was about to ask , thanks for the explanation.
looking forward trying this out! I will get back to you.
Old 16th March 2019, 03:21 AM   #30
Hi, I decided to go for 1:4 because balanced isnt needed that much and continuity of a single winding is preferable, also with half the step up for balanced it wouldnt sound the same.
Can you explain why 1:4 is preferred than 1:1 with lower I/V resistor?
Output transformers for DACsHide this!Advertise here!
PC based I2S Output for compatible DACs Vortex Digital Line Level 1 5th May 2018 07:37 PM
Zapfilter2 and current-output dacs Glenn2 Digital Line Level 5 31st October 2016 07:36 AM
D2A aragon dac with blowed output stage after the dacs... inertial Solid State 0 8th July 2013 04:04 PM
Differential output DACs, can I use only one output. oon_the_kid Digital Line Level 14 4th July 2011 02:09 AM
any info. anywhere on output stages for dacs? lt cdr data Digital Source 3 21st May 2005 04:18 AM
Copyright ©1999-2019 diyAudio
