Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
Old 1st May 2020, 10:21 AM   #911
dewdrop is offline dewdrop  Singapore
You can ask in the MoOde Audio forum, Tim or the rest are very helpful.
No harm trying. Next, I will try to see if I can control the MPD.
Old 1st May 2020, 11:26 AM   #912
Blitz is offline Blitz  Germany
you are clearly ahead in this game... looking forward to your findings...
Old 4th May 2020, 05:33 AM   #913
@Blitz, thanks to Tonno, he has a better approach writing directly to the serial interface and controlling the DAM1941 volume. He has shared it on MoOde Audio website. The MPD software mixer is not used this way.
I have tested it and it works like a treat.
Old 22nd May 2020, 09:26 PM   #914
bmxmen is offline bmxmen
Hello have any one compare dam 1021 unbalanced raw output with 1941 unbalance raw output? Im wondering why 1941 have more dynamic range 132db. I have full batery powered dam1021 ver2 .very thanks
Old 22nd May 2020, 11:28 PM   #915
soekris is offline soekris  Denmark
Balanced output by itself add 6 dB signal but only 3 dB noise....
Søren - www.soekris.dk
Old 23rd May 2020, 05:04 PM   #916
jphabc54 is offline jphabc54  United States
Hi — I’m trying to design an SPDIF input for a dam1121. Understanding that Soekris no longer recommends the max3280, can someone with eyes on a dam19x1 confirm the part number for the RS-422 receiver? It looks like it might be a DS26LV32A, but the pictures in the manual aren’t quite clear enough to confirm.
Thanks!
Old 23rd May 2020, 07:03 PM   #917
Thanks!
TI DS26LV32AT
Old 24th May 2020, 01:32 AM   #918
Thanks for confirming. Proper implementation includes Pin 4 (EN) to ground and Pin 12 (EN*) to Vcc?
Old 24th May 2020, 10:07 AM   #919
Check table in datasheet again, any other combination will work. I have both to GND.
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC moduleHide this!Advertise here!
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz soekris Vendor's Bazaar 8834 29th May 2020 12:24 AM
ANN: LF01 Discrete/Hybrid Opamp Module linuxguru Analog Line Level 73 7th October 2016 10:34 AM
discrete preamp/gain module recommendation velicko Analog Line Level 4 5th September 2016 09:36 AM
Discrete op amp headphone amplifier module, based on Marantz rjm Headphone Systems 4 10th November 2013 04:36 PM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
