Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module Please consider donating to help us continue to serve you.
Old 22nd November 2019, 08:56 PM   #751
TNT is offline TNT  Sweden
The boards need their commands - no way out of that. I'm still pondering something like a Devialet table remote. Bluetooth. The level is set in steps of dB so thats your resolution. Balance could be made by an offset - but still in 1 dB steps.
More distortion to the people!
Old 22nd November 2019, 09:04 PM   #752
rickmcinnis is offline rickmcinnis  United States
One dB can be large for balance but one has to just have a drink or two and it no longer matters!
Audio and alcohol must always be enjoyed in tandem.
It would be instructive to give this a try and hear if it makes any important difference.
The rest of my system is dual mono so the temptation is there. Maybe next year ...
Old 22nd November 2019, 09:51 PM   #753
syn08 is offline syn08  Canada
syn08's Avatar
Originally Posted by analog_sa View Post
Thanks for this gem, have always ignored them but they're great for the odd laugh.
" The output is simple: there is no audible difference. There just isn't to my ears. "
So what do you find funny/outrageous about this opinion?
Old 22nd November 2019, 11:01 PM   #754
spikestabber is offline spikestabber  Canada
Simply changing the filter changes the way the dam sounds, I can certainly tell the difference in each from the pack of 4 that I use, it couldn't possibly be the same sound as other DACs. Someone needs to measure music and compare the outputs for accuracy, not merely analyzing test tones.
Soekris dam1021-12v2 dual-mono balanced w/D882/B772 transistor mods & BAL-BAL Headamp: https://imgur.com/gallery/RVBQozq
nc400: https://imgur.com/iORCyna | TT2USB: https://imgur.com/a/p6OiS | HD800 | KEF R300
Old 22nd November 2019, 11:18 PM   #755
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally Posted by rickmcinnis View Post
Could one board have slightly different gain than the other making them impossible to match gains between both?
"Gain" is only determined by Vref. I don't see any issues sharing a single Vref among several boards.
Old 23rd November 2019, 12:30 AM   #756
soekris is online now soekris  Denmark
Vref set by 1% TL431 which mean <0.1dB signal level difference between boards. Of course typically better....
Søren
Old 23rd November 2019, 12:34 AM   #757
It's much faster and easier to just test using simple test tones, than to do comprehensive listening test....
Søren
Old 23rd November 2019, 04:22 AM   #758
syn08's Avatar
I still don't understand what's funny/outrageous about an opinion?
Not saying that you are wrong and "ASR" is right (or the other way around). But is there any grounds for taking one statement over the other? BTW, about "ASR", I know a little about his work and career, about you (and the analog guy with the tongue sticking out), absolutely nothing. Guess who, lacking any direct evidence, inspires more trust.
Old 23rd November 2019, 08:55 AM   #759
analog_sa's Avatar
It is fascinating and more than a little ironic that so many people who choose to devote their time to audio measurements are completely lacking of even basic listening abilities.
But of course this does not make their pointlessly obsessive measurements any less pointless. The important thing is they inspire trust.
Why the sudden interest in this thread?
Cornix cornici oculos non effodiet
Old 23rd November 2019, 02:56 PM   #760
syn08's Avatar
Says who?
Otherwise, good question. As you were, carry on and don’t forget to keep that tongue hanging out. It helps a lot making a point.
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC moduleHide this!Advertise here!
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz soekris Vendor's Bazaar 8676 8th December 2019 12:39 PM
ANN: LF01 Discrete/Hybrid Opamp Module linuxguru Analog Line Level 73 7th October 2016 11:34 AM
discrete preamp/gain module recommendation velicko Analog Line Level 4 5th September 2016 10:36 AM
Discrete op amp headphone amplifier module, based on Marantz rjm Headphone Systems 4 10th November 2013 05:36 PM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
Copyright ©1999-2019 diyAudio
