Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
Old 20th August 2019, 01:11 PM   #701
polaron is offline polaron  France
The Amanero is connected with an external 3.3V psu, but there is no sound. I am sure that the connections are ok.
I guess that this is due to the fact that the display is not connected. It must be necessary to use the input selector of the display. Can anyone confirm please?
There are two output 5V pins in J9. Are they there for a specific reason?
Old 20th August 2019, 05:17 PM   #702
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
So, you are connecting an Amanero to the second i2s port in order to compare it to the onboard xmos, right?
What firmware version is your board? The early firmware release did not enable the i2s port and you will need to update. The display has likely nothing to do with it as the default setting of the board is for automatic scanning of the inputs. Unless you have changed this the active input should be automatically selected.
Old 20th August 2019, 09:15 PM   #703
Yes.
I bought this board may be 6 weeks ago. I understant that the active input should be automatically selected. How can I update it, if it is what I should do?
Old 21st August 2019, 01:34 PM   #704
analog_sa's Avatar
Check the firmware version and update if not the latest. The procedure of updating via a terminal program and a serial port is described in the manual.
Old 21st August 2019, 02:04 PM   #705
Ok, I will read it carefully and try to it myself. If I can't do it, I have a friend who can. Thanks!
Old 2nd September 2019, 04:05 AM   #706
bogdandascalu87 is offline bogdandascalu87
hello, is there a 1941 board owner willingly to make some tests and post them on forum?
dam1121 fpga changes the frequency of si5xx to keep fifo functional once per 1ms.
I'm curious to know if dam1941 will make the same when useing the xmos input. Theroretically if fpga and xmos run sync, those changes in frequency would't be necessary, but who knows?
So, anybody having 1941, a cheap logic analizer to log the i2c and some time? I will give the beer!
Old 2nd September 2019, 05:54 AM   #707
TNT is offline TNT  Sweden
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
post #8515
For DAM boards with on-board USB, no clock adjustments Sören says.
More distortion to the people!
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC moduleHide this!Advertise here!
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz soekris Vendor's Bazaar 8552 Yesterday 05:12 PM
ANN: LF01 Discrete/Hybrid Opamp Module linuxguru Analog Line Level 73 7th October 2016 10:34 AM
discrete preamp/gain module recommendation velicko Analog Line Level 4 5th September 2016 09:36 AM
Discrete op amp headphone amplifier module, based on Marantz rjm Headphone Systems 4 10th November 2013 04:36 PM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
Copyright ©1999-2019 diyAudio
