Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
Old 7th July 2019, 04:02 PM   #671
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module Send a message via AIM to Peter Daniel
Yes, the volume control still works without power to display.
The on-board power trace has been cut and separate power is hooked up through toggle switch.
File Type: jpg 6D47AF3B-2F30-467E-920E-D4A527873855.jpg (737.9 KB, 541 views)
www.audiosector.com
Old 7th July 2019, 04:41 PM   #672
rickmcinnis is offline rickmcinnis  United States
Thanks, Peter,
I could see with the multimeter that that trace is the +5 volts trace - and I see that is what you are switching on and off - I am amazed that the rotary controller still works.
And then I decided to look closer at the schematic and see the rotary controller is connected directly to the main board so if one just wants a volume control no need for all of the other stuff at all.
Of course I ordered the parts for the board yesterday and all I need is a rotary controller.
I do not doubt this has been said before though I missed it and thought I would post this in case someone else just wants a volume control.
Take care,
Old 22nd July 2019, 04:05 AM   #673
samsie is offline samsie  Hong Kong
Default cut the PCB (display board) if headphone out is not needed
I want to make the Dam 1941 DAC as small as possible and I do not need the headphone control.
According to the manual, " if you donít need the headphones control section you can cut the PCB (display board) at the point where the ground layer ends".
I will lost button S4 and S6 if I cut the display board PCB at the point where the ground layer ends. Does it mean I cannot setup the remote control afterwards via using those button?
Sam
Old 24th July 2019, 07:55 AM   #674
vwvwbg is offline vwvwbg  Taiwan
Hi Soren!
Does crossfeed function in serial work?
I can't find status message in TX.
By the way, the default output is line out.But in manual says crossfeed only valid when headphones are selected.
So, could you please add the output select function for serial.
Thanks!!
Old 27th July 2019, 05:16 PM   #675
wushuliu is offline wushuliu  United States
wushuliu's Avatar
I have a stupid question. Wiring up my 1921 for unbalanced for RCA, what outputs should I use? '+' and 'GND' or '+' and '-'? I never use balanced outs so am not as familiar with interpreting the outputs. Thanks.
Old 27th July 2019, 07:51 PM   #676
TNT is offline TNT  Sweden
GND & +
More distortion to the people!
Old 27th July 2019, 07:54 PM   #677
wushuliu's Avatar
Originally Posted by TNT View Post
GND & +
Ok, that's what I thought. Just wanted to be sure. Thanks.
Old 2nd August 2019, 04:11 PM   #678
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
Has anyone tried battery power for any of these DAC boards?
Greg
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, DCB1, VHEX + USSA-5, BA-3 Pre, DCG3, USSPA, Transcendent Sound Masterpiece
Old 7th August 2019, 11:12 PM   #679
wushuliu's Avatar
Ok, I stupidly removed the muting ICs on my dam board. Does anyone know the part type/number so I can replace them?
Old 8th August 2019, 12:35 PM   #680
Can you not place a jumper wire across the needed points?
Would have to be better than having a relay.
I did not realize there were relay ICs on the board.
Could you show where they are or is it obvious once you know they are there?
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC moduleHide this!Advertise here!
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz soekris Vendor's Bazaar 8470 21st August 2019 12:32 AM
ANN: LF01 Discrete/Hybrid Opamp Module linuxguru Analog Line Level 73 7th October 2016 10:34 AM
discrete preamp/gain module recommendation velicko Analog Line Level 4 5th September 2016 09:36 AM
Discrete op amp headphone amplifier module, based on Marantz rjm Headphone Systems 4 10th November 2013 04:36 PM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
Copyright ©1999-2019 diyAudio
