Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
Old 13th June 2019, 04:18 PM   #661
Blitz is offline Blitz  Germany
I guess you neededto cut some traces, no ? Do you have detail pictures where you did that ?
Old 13th June 2019, 04:31 PM   #662
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module Send a message via AIM to Peter Daniel
The trace powering display was cut here:
File Type: jpg 2DA6F9C4-64E3-488A-A25D-54CCB7F6B006.jpg (976.3 KB, 422 views)
www.audiosector.com
Old 13th June 2019, 04:44 PM   #663
Powering USB was described here: dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
www.audiosector.com
Old 13th June 2019, 05:36 PM   #664
Thx a lot... And did you feel that a highend shunt reg like the Salas impoved the display quality as well..?... just kidding, but you made a remarkable effort here... will follow you trail... i want a shunt regged display as well
Old 13th June 2019, 05:54 PM   #665
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
How about just a power switch to cut the display board off when listening?
I just added an Arduino to a friend's DAM1021 and discovered nothing less than a power switch can make the Arduino disappear.
Old 13th June 2019, 06:40 PM   #666
euro21 is offline euro21  Hungary
I use isolated (Dimdim's ArDAM Lite GB for ArDAM Lite bare PCBs separated PSU for Arduino and isolation) serial control and display for my 1941.
Listening the music no effect whatsoever if control (power) on or off.
Old 15th June 2019, 04:52 PM   #667
That is actually a very good suggestion. I just installed a switch that disconnects power from the display board. With a good power supply, the difference is not that much, especially when exactly same components are being used in both display and digital regulators, however with display off, I have a feeling that the sound is less edgy, with more smoothness. I like it with display off, and volume control still works.
File Type: jpg 245DCC79-5366-46E8-96C0-81C8BA974BB6.jpg (580.7 KB, 345 views)
www.audiosector.com
Old 24th June 2019, 03:15 AM   #668
kenneth_obee is offline kenneth_obee  Hong Kong
I modified dimdim's ardam1021-lite-project (ArDAM1021 Lite Project | Dimdim's Blog) so that it displays input, sample rate, filter, type and volume in one screen. I didn't use the IR receiver of ardam1021-lite but keep original IR and volume control given by dam1941.
I also added an one way isolator so that it isolates the arduino nano with the dam1941. Since the isolator that I have is one way only, I only connects the TX of dam1941 to RX of nano.
Old 24th June 2019, 03:21 AM   #669
Hi Soren,
When I work on the Arduino nano, I found that there is no message sent from dam1941 when I press "output" and "xfeed" buttons.
Is it possible to add new message code in future firmware release so that we know such button is pressed?
In addition, I have 2 questions:
1. Right now when I press "output" button, it would lower the volume to -30 automatically. Why is it so and what's the purpose of this output button for?
2. Can the volume/filter/input setting be saved? Each time when I power on it automatically reset.
Old 7th July 2019, 03:31 PM   #670
rickmcinnis is offline rickmcinnis  United States
Peter Daniel,
Wanting to be sure I understand the display on and off switch - without power to the display board the volume control will still work? Or is something else being switched? Looks like the power trace - am I confusing something?
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC moduleHide this!Advertise here!
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz soekris Vendor's Bazaar 8433 12th May 2019 07:19 PM
ANN: LF01 Discrete/Hybrid Opamp Module linuxguru Analog Line Level 73 7th October 2016 10:34 AM
discrete preamp/gain module recommendation velicko Analog Line Level 4 5th September 2016 09:36 AM
Discrete op amp headphone amplifier module, based on Marantz rjm Headphone Systems 4 10th November 2013 04:36 PM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
Copyright ©1999-2019 diyAudio
