Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
Old 10th January 2019, 09:29 PM   #181
Blitz is offline Blitz  Germany
C11 on the display board...another 0,47uF ? Fine...
Old 10th January 2019, 10:55 PM   #182
soekris is offline soekris  Denmark
Missed that on the schematics and BOM, but yes, another 0.47u decoupling capacitor.
Søren
Old 12th January 2019, 12:46 AM   #183
kin1111kin is offline kin1111kin  Hong Kong
The headset output is there?Thx
Anyone can play dsd file for native
Old 12th January 2019, 01:59 AM   #184
As I just said:
The buffer board is just a basic one without headphone amplifer (see schematics for the details). The headphone part of the display board is all in one side, actually designed to be broken of or sawed of if not needed.
Yes, it plays DSD, please see data on website or manual....
Søren
Old 12th January 2019, 02:48 AM   #185
Dubulup is offline Dubulup
Søren - killer product, simple to use and I'm sure plenty to tweak for fun. I wanted something simple to use with my 300B headphone/pre amp.
Old 12th January 2019, 10:29 AM   #186
I want make the built-in headphone amp , how to connect?
Old 12th January 2019, 06:15 PM   #187
GhostMM is offline GhostMM  France
Hello,
I want to use a different color for the matrix led, vishay propose a variant with orange color... TDSO3150-L or the TDSO3155 could work ?
Thank you !
Old 12th January 2019, 06:18 PM   #188
Originally Posted by GhostMM View Post
Hello,
Thank you !
Most standard 10mm ones should do, but check pinouts and light output.... Please note that the specified Vishay type are with selected density....
Søren
Old 12th January 2019, 11:55 PM   #189
Petter is offline Petter
Default Measurements?
Soeren, I know measurements for linearity probably won't be that great since this is an R2R DAC with other benefits. I am still curious if there are measurements of say the factory complete product. Not everybody wants to use this JUST to listen to music to ...
All the best
Petter
Old 13th January 2019, 12:09 AM   #190
Which rs232 adapter are you guys using ? Something like this: PL2303HX Kabel FTDI USB to TTL Konverter Modul Adapter Arduino zu UART RS232 | eBay ?
I believe there are different versions ...5V...3.3V...and I did not see a power connector pon for this adapter in the manual, only tx, rx and ground, right ?
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC moduleHide this!Advertise here!
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz soekris Vendor's Bazaar 8257 Today 12:11 AM
ANN: LF01 Discrete/Hybrid Opamp Module linuxguru Analog Line Level 73 7th October 2016 11:34 AM
discrete preamp/gain module recommendation velicko Analog Line Level 4 5th September 2016 10:36 AM
Discrete op amp headphone amplifier module, based on Marantz rjm Headphone Systems 4 10th November 2013 05:36 PM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
Copyright ©1999-2019 diyAudio
