Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
Thread Tools
Old 26th December 2020, 01:18 PM   #1021
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
Originally Posted by euro21 View Post
Jean-Paul, IMHO you generalize strongly. :-(
At least as much -poorly designed- SS device has "coloration", irritating tone as tube ones.
BTW where are -in this case- noise and "coloration"? :-p
https://www.diyaudio.com/forums/atta...1-spectrum-jpg
Noise floor is high and distortion is high compared to good DS DACs - even
compared to PCM1704 it's pretty inferior.
TCD
Old 26th December 2020, 04:17 PM   #1022
euro21 is offline euro21  Hungary
I think you misunderstood my conversation with Jean-Paul.
This spectrogram is only the preamp (after the 1941).
Old 26th December 2020, 10:54 PM   #1023
Yes, my apologies, I thought it was pretty abysmal for a DAC.
TCD
Old 5th January 2021, 10:06 PM   #1024
Blitz is offline Blitz  Germany
Quick question...I figured that my tube amp likes a little higher level input. So, i like what I hear when we are at +2 or + 4 of the Dam1941....i just wonder: How degenerative is this ?...so how much information are we loosing within the DAC when going above 0 ?
Old 5th January 2021, 10:12 PM   #1025
TNT is online now TNT  Sweden
Digital gain is about math. -2 or +2 dB is "the same thing". In the case of minus you are throwing away LSB "bits" and on plus, your have to suck in (LSB) bits - 1 bit for every 6 dB.
You do the math
I would say like this - even if you put it at 0 and think you have a bit clean conversion - think again as the filters are also math so everything is recalculated anyways before conversion compared to the CD record. If you like the sound then you are OK - no?
So + is no info loss but minus (attenuation) really is. Then you have the rounding errors for both directions in the math...
More distortion to the people! Timing . . . . is paramount.
Old 6th January 2021, 09:47 PM   #1026
fedde is offline fedde  Netherlands
Well... If clipping would occur, this would have more impact than some bits sucked in..
(Depending on source material and amount of attenuation in the digital filters).
So I only would do this with low volume material to be on the safe side...
http://www.fedde.nu, gainclone, non-oversampling DAC and open baffle audio projects...
Old Today, 06:21 PM   #1027
Well, I looked at it with an Oscilloscope while playing a sinus 1000hz 0db...full signal. With 0db you have a clean sinus, the more you add like +4 the more it does not look like a sinus anymore, becomes more a non symetrical triangle.
Different question:
I am reading always about transients in a music signal like the strike of a drummer etc can create impulses which are like 16db bigger than the musical signal...well what does mean in terms of Vpp-Envelope really ? What I mean: When I play a sinus digital 0db, so full digital signal: And I measure this with an osci: Is this the biggested technical possible analog signal the DAC can send to whatever comes next ? Or can those transients become even bigger than that ?
Old Today, 07:06 PM   #1028
0 dBfs is the biggest. More and it will clip - thats way you start to see a triangle. Most CD records are recorded with its normal (mean?) level 10-30 dB lower than 0 and can therefore handle transients of 16 dB and more. It works pretty well :-)
  Reply to this post
dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC moduleHide this!Advertise here!
Thread Tools
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz soekris Vendor's Bazaar 9622 Today 05:30 PM
ANN: LF01 Discrete/Hybrid Opamp Module linuxguru Analog Line Level 81 11th October 2020 10:36 AM
discrete preamp/gain module recommendation velicko Analog Line Level 4 5th September 2016 10:36 AM
Discrete op amp headphone amplifier module, based on Marantz rjm Headphone Systems 4 10th November 2013 05:36 PM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
