Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Fastener Super Store
Thread Tools
Old 22nd August 2018, 03:17 PM   #2
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Just when you need those Torx button screws so the kids don't take the bathroom doors off in high schools across the good ol' USA.
Old 24th August 2018, 06:45 PM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
Some options for black metric sheet metal screws would be nice. That's a niche not covered elsewhere. I'd be interested in some M3x0.5, 10-12 mm length, Torx/Torx-Plus drive, oval or flat head with a black oxide finish.
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 24th August 2018, 08:11 PM   #4
simon7000 is offline simon7000  United States
!!!! There are also one way straight slotted screws that are not easily removed. Slot shoulders to drive in and tapered ramps in the reverse direction.
One of my favorite house warming kits for lawyers etc., contains both sizes of sink traps, hammer, small saw, screwdriver assortment, pipe wrench, crescent wrench and a left handed threaded light bulb! They are made for housing projects so the tenants only steal one bulb from the common areas.
Amazing what you can find these days.
Old 24th August 2018, 08:14 PM   #5
Tom
Easy to make, use the gun black chemicals. Then when dry place them on a tray and lightly spray paint black from 360 degrees around. Highs the tray to expose unpainted area and repeat the light spray.
Old 30th August 2018, 01:32 AM   #6
chrisb is offline chrisb  Canada
Simon-I’m thinking an OEM such as Tom has better things on which to spend his time?
Itís been a slice kids
Old 30th August 2018, 02:13 AM   #7
Originally Posted by chrisb View Post
Simon-Iím thinking an OEM such as Tom has better things on which to spend his time?
An OEM should have enough quantity to get a commercial house to do the process for them. The method mentioned is good for several hundred pieces at a time. It is how my supplier does it.
Old 30th August 2018, 02:36 AM   #8
Tom - Fastener Superstore has lots of options, but not at quick glance the exact combination you cite. With a sufficient order and lead time, who knows how far theyíd care to go?
Machine Screws | Metric | Steel / Black Oxide | Fastener SuperStore
I think I used these guys for three pitch sizes of black oxidized button head hex machine screws about 10 or so years back. Their website sucks, but phone & in person service was good back then.
Products | FastenerForce One Resources
The other industrial suppliers we used in volume -Richelieu, and Hafele - have little to offer in this category as well, so save your Google pixels.
Old 30th August 2018, 02:39 AM   #9
Simon - how are the referse threaded bulb sockets identified so a legimate replacement isn’t a risk?
Old 30th August 2018, 02:57 AM   #10
Simon - how are the reverse threaded bulb sockets identified so a legimate replacement isnít a risk?
They are not! Not even on the package. They just won't screw into the wrong socket.
Fastener Super StoreHide this!Advertise here!
Thread Tools
The Tubecad Super-Simple, Super-Fine FET Circuit in HPA Configuartion EUVL Headphone Systems 15 22nd December 2019 06:16 PM
Super High End driver store? eriksquires Multi-Way 31 3rd July 2016 02:33 PM
"Component super store" d to the g Parts 4 18th March 2008 04:11 PM
Speaker grill/cover and grill fastener questions. marchel Multi-Way 4 22nd January 2008 02:41 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
