Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VHex+ amplifier modules, kits and boards
Old 26th October 2018, 01:53 PM   #21
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Originally Posted by maty tinman View Post
Very interesting your new amp.
Simpelstark PLUS V1.3 kit (2 x PCBs + parts) – Virtual Zero Audio Store
SNR A-weighted at 1 watt and 100 watts?
Post your Solid State pics here.
Hi Maty,
I have actually never measured its SNR some proper way, as I didn't see any practical reason for that - it's one of the quietest amplifiers I ever dealt with
Anyway, if I have time, I will measure it for the marketing purpose
Valery
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 26th October 2018, 03:36 PM   #22
vzaichenko's Avatar
Originally Posted by vzaichenko View Post
Hi Maty,
Valery
By the way, I don't see any sense in measuring the SNR of a power amp at 1W if you know the SNR value at 100W. Just take the one at 100W and subtract 40db, right? The signal is 40db lower, the noise is the same.
http://vzaudio.com/
Old 26th October 2018, 03:45 PM   #23
maty tinman is offline maty tinman  Spain
maty tinman's Avatar
In theory, you need to substract 20 dB.
Old 26th October 2018, 04:10 PM   #24
vzaichenko's Avatar
Right! 100 times in power = 10 times in Vrms.
My mistake.
http://vzaudio.com/
Old 26th October 2018, 04:11 PM   #25
vzaichenko's Avatar
Anyway - if we know SNR at full swing - easy to calculate all the rest.
http://vzaudio.com/
Old 26th October 2018, 04:16 PM   #26
The problem with the SNR is in how it has been measured. Very few times the manufacturers specify it!
To be able to compare the easiest is to use A-wighted to 1 watt / 8 Ohms.
An example, John Atkinson (Stereophile) with Pass Labs XA200.8:
Pass Laboratories XA200.8 monoblock power amplifier Measurements | Stereophile.com
The unweighted, wideband signal/noise ratio, ref. 1W into 8 ohms and taken with the input shorted to ground, was an excellent 83dB. This improved to 88.2dB when the measurement bandwidth was restricted to the audioband—and was even better, at 92.1dB, when the measurement was A-weighted. Like the other Pass Labs amplifiers we have reviewed, the XA200.8 is quiet.
As with the XA60.8 monoblock that we reviewed in December 2017, both the odd and even harmonics of the 60Hz power-supply frequency were present in the amplifier's noise floor, though these all lay at or below –100dB ref. 1W into 8 ohms (fig.3).
Fig.3 Pass Labs XA25, spectrum of 1kHz sinewave, DC–1kHz, at 1W into 8 ohms (linear frequency scale).
Old 26th October 2018, 04:34 PM   #27
vzaichenko's Avatar
OK, tomorrow I'll try to arrange a filter and measure at 2.83Vrms (that's 1W @ 8 ohm), dividing by "no signal" Vrms measurement.
http://vzaudio.com/
Old 27th October 2018, 09:34 PM   #28
vzaichenko's Avatar
Default SNR
OK, guys... it appeared to be not that easy with the gear I have in hand.
My True RMS voltmeter has got the resolution of 100uV and it shows 000.0 mV with no signal at the output.
I switched to the oscilloscope - minimum value it can measure is 80uV, however, it also shows zero. OK, let's take the worst value that would be rounded down to zero - that would be 39uV of the noise signal.
That gives us:
SNR (2.83V) = 97db (1W @ 8 ohm)
SNR (28.3V) = 117db (100W @ 8 ohm)
Then I have connected my audio analyzer and tried to see the spectrums.
The first picture shows the spectrum with the amplifier off.
We see a 50Hz artifact - some kind of a ground loop caused by the way the analyzer is connected to the amplifier.
The second picture is 28.3V RMS output (same measurement scale, I didn't touch any settings) - we see the same artifact a little bit grown up, all the rest is very close to the "off" situation.
That's the best I can do at the moment. Need some uV RMS meter for more precise measurements.
http://vzaudio.com/
VHex+ amplifier modules, kits and boardsHide this!Advertise here!
Cable Kits For ICEpower 250A/500A/1000A Amplifier Modules beaux1977 Swap Meet 3 2nd February 2017 08:08 PM
NEW Audio amplifier kits, modules and many others. Cristi Vendor's Bazaar 828 11th November 2015 09:40 AM
LM3886 Chip Amplifier Stereo PC Boards, Kits, and Assembled & Tested Modules Jackson Audio Vendor's Bazaar 2 8th April 2007 01:17 AM
