Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Modulus-686: 380W (4Ω); 220W (8Ω) Balanced Composite Power Amp with extremely low THD
Old 6th August 2019, 04:48 PM   #1131
tomchr is online now tomchr  Canada
tomchr's Avatar
Originally Posted by tcpip View Post
Thanks a lot for the first useful response. I needed a back-of-envelope answer. I guess I should have specified "I want a figure +/-1V, and with reasonable assumptions" when I asked.
My answer won't be accurate to 1 V. Think about it... Mains variation alone would cause 3.3 V variation.
If you want 1 V precision, use a regulated supply.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 6th August 2019, 04:57 PM   #1132
tcpip is offline tcpip  India
Somehow, I have succeeded in confusing all of you about the context of my question. I don't need a very precise answer. I just wanted to know a "nominal" answer. I'm not trying to do anything with edge cases or corner cases. Sorry about this. You're of course correct that I won't get even a 10% accurate answer if I map the nominal to the real world. (I live in a country where the real mains voltage is often 30% lower than the nominal figure in many parts of the country. Voltage stabilizers are a household device in every household, and every store selling a refrigerator or AC will sell you a compatible voltage regulator too.)
But I just needed a nominal figure, with "reasonable" assumptions on xfmr, diodes, etc.
Old 6th August 2019, 05:04 PM   #1133
tomchr's Avatar
Well, in your case then: There will be some voltage present on the output of the power supply. Maybe. If it feels like it...
Under nominal conditions, expect around 32-33 V with a 24 VAC transformer.
Tom
Old 6th August 2019, 05:57 PM   #1134
BrianL is offline BrianL  United States
Modulus-686: 380W (4&#937;); 220W (8&#937;) Balanced Composite Power Amp with extremely low THD
As a rough rule of thumb I multiply the transformer's secondary voltage by 1.5 to account for high line voltage, higher no-load voltage on the transformer secondary, and because it's an easy number to remember. If that number pushes any limits, then it has to be considered more thoroughly.
bel
Old 12th August 2019, 04:37 PM   #1135
tomchr's Avatar
Yeah, and under nominal conditions, under load, the DC voltage is more like 1.3-1.35x the AC output of the transformer. It's closer to 1.4x at idle.
Tom
Old 13th August 2019, 02:50 PM   #1136
I don't like the idea of leaving XLR Pin 3 floating. That means the inverting input of the differential receiver is floating.
I prefer to connect XLR Pin 3 to the RCA shell (along with XLR Pin 1). Unfortunately, it isn't possible to have both RCA and XLR connectors hooked up without using a switch to select between the two, though.
I found this in Self's Audio Power Amplifier Design Handbook:
Old 15th August 2019, 07:15 PM   #1137
tomchr's Avatar
Oh, that's a neat trick! Basically, you take a standard differential input and connect the single-ended input through a 100 Ω resistor to the non-inverting input of the opamp. When the XLR is unplugged, the opamp works as a buffer. Nice!
The obvious drawback is that the circuit won't work with both the XLR and RCA sources plugged in. It has to be one or the other.
Tom
Old 15th August 2019, 11:32 PM   #1138
Yes, it was never intended to work with both sockets connected to cables.
And the input circuit of the Self preamp in Linear Audio doesn't even have these resistors, IIRC.
Old 16th August 2019, 07:49 AM   #1139
zgtc is offline zgtc  Europe
zgtc's Avatar
We had a "similar" discussion some months back in the THAT thread, about the Witlock's JENSEN AN-003 note. That note shows an unbalanced to balanced interface that uses only a pair of resistors and a cap, no transformers involved.
I think the consensus was that
THAT Driver differential output > Balanced output > pseudo-differential cable
and
It's not the best way of doing things, but better than not doing it.
Old 16th August 2019, 10:58 AM   #1140
I think the consensus was that and
I'm confused here... We were discussing inputs and your response mentions output.
Modulus-686: 380W (4&#937;); 220W (8&#937;) Balanced Composite Power Amp with extremely low THDHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2421 17th May 2019 12:10 AM
SDTRANS384, MODULUS-86, POWER SUPPLU AND TROIDALS, Audio nirvana 8 alnico potstip Swap Meet 14 14th August 2015 01:06 PM
cabiant for Xpload 220w Hosam Subwoofers 19 12th March 2011 04:37 AM
Extremely low power and low loss transformers percy Tubes / Valves 12 23rd February 2005 10:30 AM
Extremely low power first amp problem m0rg Tubes / Valves 9 16th February 2004 11:05 PM
Copyright ©1999-2019 diyAudio
