Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Modulus-686: 380W (4Ω); 220W (8Ω) Balanced Composite Power Amp with extremely low THD
Old 21st June 2019, 06:31 PM   #1101
ukhopeful is offline ukhopeful  United Kingdom
Hi Mark
You've misunderstood the purpose of the drill bits in this discussion - they're being used as formers to bend the LM3886 leads to orient the devices through degrees.
Cheers
Colin
Old 21st June 2019, 06:40 PM   #1102
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Oops, thanks for the correction.
Modulus-686: 380W (4Ω); 220W (8Ω) Balanced Composite Power Amp with extremely low THDHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2421 17th May 2019 12:10 AM
SDTRANS384, MODULUS-86, POWER SUPPLU AND TROIDALS, Audio nirvana 8 alnico potstip Swap Meet 14 14th August 2015 01:06 PM
cabiant for Xpload 220w Hosam Subwoofers 19 12th March 2011 04:37 AM
Extremely low power and low loss transformers percy Tubes / Valves 12 23rd February 2005 10:30 AM
Extremely low power first amp problem m0rg Tubes / Valves 9 16th February 2004 11:05 PM
Copyright ©1999-2019 diyAudio
