Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Modulus-686: 380W (4Ω); 220W (8Ω) Balanced Composite Power Amp with extremely low THD
Old 5th February 2019, 03:26 PM   #1011
tomchr is offline tomchr  Canada
tomchr's Avatar
Those should work. At 12 A rating per terminal, they're certainly plenty beefy.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 5th February 2019, 05:04 PM   #1012
wcwc is offline wcwc  United States
Do,
How tall are the heatsinks you are using? 3U or 4U?
Old 5th February 2019, 07:52 PM   #1013
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Originally Posted by wcwc View Post
Do,
142mm, so roughly 3U
Do
PREAMPs : AMB α10 + USSPA | LDR3x + USSPA | AMPs: AMB β24 | USSA5 | TGM8 | VZ Audio NS OPS | FC-100 | Modulus-686 |
DACs : Mirand AK4490 + Discrete Output | Speakers : Troels Gravesen ATS-4 | Sagwee LT V3 |
Old 7th February 2019, 03:42 AM   #1014
pinnocchio's Avatar
Tom
Installed them. They worked beautifully and keep the wire at a good distance now.
Old 7th February 2019, 07:09 PM   #1015
tomchr's Avatar
Sweet! I'll add a note in the documentation that if you need vertical wire entry, you have options.
Tom
Old 8th February 2019, 02:55 AM   #1016
zman01 is offline zman01  Bangladesh
Modulus-686: 380W (4&#937;); 220W (8&#937;) Balanced Composite Power Amp with extremely low THD
Do,
Can you share an image please?
Always good to learn about practices that can keep the wiring well connected and tidy!
Old 8th February 2019, 06:14 PM   #1017
pinnocchio's Avatar
Originally Posted by zman01 View Post
Do,
Sure, I'll do this shortly.
I fitted everything in the chassis and made an aluminum plate to hold the two SMPS for the amp. All that is needed now is power cabling, everything else is done.
Ciao!
Do
Old 9th February 2019, 02:41 AM   #1018
tomchr's Avatar
Which SMPS did you go with?
Old 10th February 2019, 06:08 PM   #1019
pinnocchio's Avatar
Hi Tom,
The SMPS800 that you had suggested. I recapped them completely since only the output caps were of good quality. The cheap Chinese caps were still working properly but for the long run, it is better to use quality caps.
Cresnet uses only quality caps in his designs. All the SMPS I got from him had reputable brands. I still have a few of his SMPS but they are higher voltage and are reserved for other projects.
Today I will test the amp with a scope and output some sinus and square wave before I plug it into the speakers. I will post pictures of the final build shortly.
All the best!
Do
Old 10th February 2019, 09:15 PM   #1020
pinkphiloyd is offline pinkphiloyd  United States
Has anyone that's using the SMPS300RE from Connex happened to measure it's switching frequency, or seen this info published anywhere, by any chance? I haven't been able to find anything in the way of an actual data sheet and couldn't find this info posted on the website anywhere. I'd appreciate any help.
Modulus-686: 380W (4&#937;); 220W (8&#937;) Balanced Composite Power Amp with extremely low THDHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2421 17th May 2019 12:10 AM
SDTRANS384, MODULUS-86, POWER SUPPLU AND TROIDALS, Audio nirvana 8 alnico potstip Swap Meet 14 14th August 2015 01:06 PM
cabiant for Xpload 220w Hosam Subwoofers 19 12th March 2011 04:37 AM
Extremely low power and low loss transformers percy Tubes / Valves 12 23rd February 2005 10:30 AM
Extremely low power first amp problem m0rg Tubes / Valves 9 16th February 2004 11:05 PM
Copyright ©1999-2019 diyAudio
