Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 13th July 2020, 10:53 PM   #361
phile1 is offline phile1  France
hi
just a noob question. I need to reach some low voltages, 3.3V & 1.8VDC.
what's the best way to feed a SLS module :
- your transformer 4.2VAC => to a SLS AC version (given that after rectification you have 5.1VDC to feed the LT3045)
- or a rather good LPS like a zerozone, 5VDC output => to a SLS DC version
thanks for advice
Rgds
Old 14th July 2020, 04:12 PM   #362
Hi Micheal,,
I've got a 2nd question :
As the datasheet mentions & you too, when we have 1 LT3045, we roughly need Vout-Vin=1V to get a decent ripple noise rejection.
The SLS has 2 rows of LT3045, thus a design with 2 LT3045 in series, so :
- on the PCB, do we have 1V diff beteween the 2 rows of LT3045 ? I think "yes" given the datasheet
- and so, could you please confirm that with the "special" PS, we need 2V diff between in & out, and not 1V like for the other PS you manufacture ?
thanks for reply
Rgds
Old 14th July 2020, 09:28 PM   #363
Stammheim is offline Stammheim  Germany
Hi phile1,
the recommendation of the power source depends on your current need. In case of 2A for example and 1,8VDC output voltage that would mean 6,4W of heat - we recommend <4W max (less is better) in sum for passive cooled setups.
Usually we adjust the first stage to +0,8V additional voltage. As shown in the datasheet the Vdifference depends on the current need, for low currents a higher Vdifference can be set, lower for higher current. We recommend to set the Vdifference below +0,5VDC.
We have also published some measurements as well, which transformer voltage is needed to reach a certain V/A. Visit our FAQ
If you have any questions, feel free to contact us via our website.
I'm not sure what you mean with the special PS?
Best regards
Michael | MPAudio
www.MPAudio.net
  Reply to this post
low noise Pre-Amp / DAC power supply MJE15034 TL072 Regulator based on STUDER 900 yoshisoakland Power Supplies 305 Yesterday 06:08 PM
FS: TPS7A4700 low noise power supply SALE!!!!! mravlca Vendor's Bazaar 8 18th March 2017 08:46 PM
Ultra Low Noise and Low Power Consumption OCXO ULNOCXO Vendor's Bazaar 21 6th July 2014 09:39 PM
Ultra Low Noise - Ultra Low Impedance - Ultra big Problems! Stefan0815 Analog Line Level 2 14th January 2014 06:01 AM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 04:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
