Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Sale of special quality lamps
Old 1st December 2017, 06:46 PM   #11
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Moved to the Vendors area.
Old 4th December 2017, 01:00 PM   #12
kszd is offline kszd  Ukraine
kszd's Avatar
EM4 PHILIPS 70% glow broken base 25 $
EM4 PHILIPS 45% glow broken base 10 $
EM4 PHILIPS 80% glow 25 $
EM4 VALVO 40% glow broken base 10 $
EM4 ?? 70% glow broken base 25 $
EM4 ?? 120% glow 45 $
all together 100 $
EM1 PHILIPS 60% glow 25 $
EM1 PHILIPS 40% glow broken base 15 $
EM1 PHILIPS 70% glow broken base 30 $
all together 50 $
AM1 ?? 100% glow 45 $
C \ EM2 TELEFUNKEN 75% glow 25 $
AM2 TELEFUNKEN 50% glow 15 $
all together 60 $
EM11 TELEFUNKEN 80% glow 15 $
EM11 TELEFUNKEN 90% glow 25 $
EM11 TELEFUNKEN 80% glow 15 $ broken base
EM11 VALVO 80% glow 15 $ broken base
EM11 RWN (RFT) 57 year 100% new 35 $
all together 100 $
EFM11 TELEFUNKEN 50% glow 15 $
EFM11 TELEFUNKEN 80% glow 20 $
EFM11 TELEFUNKEN 100% glow 40 $
EFM11 VALVO 70% glow missing key 15 $
all together 70 $
1629 ?? 90% glow 10 $
1629 SILVANIA 100% glow 15 $
1629 TUNG-SOL 100% glow 15 $
6U5 \ VT-98 100% glow 20 $
all together 40 $
Old 2nd May 2018, 09:17 AM   #13
kszd's Avatar
lot used - not tested
ECH81 TESLA - 37 PCS
EBF80 TUNGSRAM - 1 PCS
EBF89 RFT -1 PCS
10$
lot EF80 -32PCS
nominal - 10 ma
TELAM 9.7MA-16.2MA 5PCS
ERA 6MA 6MA 2 PCS
MATSUSHUTA 6BX8 14.2 MA
TUNGSRAM 9.5MA-12.8 MA 8PCS
TUNGSRAM 8.2MA
RFT 10MA 10MA 2PCS
TESLA 13.2MA-16MA 6PCS
WF 9MA-13.5MA 7 PCS
WF 6MA 8MA 2PCS
20$
lot EF800 gold pin -7PCS
nominal - 10 ma
10ma-13 ma 6PCS
6ma 1pcs
35$
lot EF89
nominal - 9 ma
TELAM RC 10MA-10.3MA 5PCS
TELAM RC 8MA
TELAM JA 10.3MA-11MA 3PCS
TELAM JA 8.5MA 8.5MA 2PCS
SILVANIA 10.1 MA
TUNGSRAM 9.8 MA
TELAM 6 MA
TELAM 10.2 MA 11.5 MA no mark 2PCS
35$
lot EF85
nominal - 10 ma
TUNGSRAM 8 MA 10ма 12 ма
PHILIPS 15 ma 12 ma (no mark)
20$
lot ECH81
TESLA - 2 PCS 100%\100%
TUNGSRAM 90%\100% (no mark)
Valvo 70%\70%
PHILIPS 2 PCS 110%\100% 90%\70%
DARIO 50%\90%
MULLARD 3 PCS 100%\100% 110%\120% 60%\70%
SIEMENS 100%\110% box
60$
6p14p (EL84\6BQ5) used 1$ pcs
tested for serviceability
in the presence of more than 500 pieces
50 pieces 40 $
100 pieces 70 $
6F6M1 (6F6GT\G) metal base SPECIAL QALITY Tubes 50`s tested 14$ PCS
in the presence of more than 50 pieces
RARE TUBE USSR 1915-1920
ST-6 TETRODE dead no heater- display only Europe 4-Pin+1 10$
ST-83 TRIODE dead no heater- display only Europe 4-Pin 10$
PT-2 TRIODE dead no heater- display only Europe 4-Pin 10$
R-5 TRIODE dead no heater- display only Europe 4-Pin 10$
MICRO TRIODE dead no heater- display only Europe 4-Pin
METAL BASE RARE 1915-1917 YEARS 20$
UT-40 POWER TRIODE dead no heater- display only Europe 4-Pin
ROUND BALL 10$
UT-40 POWER TRIODE dead no heater- display only Europe 4-Pin 10$
UT-1 POWER TRIODE dead no heater- display only Europe 4-Pin 10$
VO-188 ( RGN2004)Full-Wave Vacuum Rectifier dead no heater-
display only Europe 4-Pin 50s 3$
ALL 9 LAMP - 75$
SO-148 40s PENTODE NOMINAL 7.5MA TEST 10MA 125% Europe 5-Pin+1 25$
SO-124 40s PENTODE NOMINAL 5.4MA TEST 5.9MA 105% Europe 5-Pin+1 25$
SO-122 40s POWER PENTODE no output heater ok loose base- display only Europe 5-Pin+1 dead 10$
SO-122 40s POWER PENTODE heater ok has internal element short display only Europe 5-Pin+1 dead 10$
SO-192 40s POWER DIRECT PENTODE NEW heater ok STATUS AS IS\NOT TESTED METAL BASE Europe 5-Pin 20$
T-116 TELEFUNKEN TETRODE heater ok STATUS AS IS \ NOT TESTED Europe 4-Pin+1 10$
LS-3 TELEFUNKEN TRIODE dead no heater- display only 4$
SO-118 GLOBE TUBE TRIODE Europe 5-Pin NOMINAL 3MA TEST 3.5MA 115% 40$
6L6S METAL BASE (6L6G) 1938 YEAR 70 MA leaky 15$
6S4S RARE SILVER PLATE has internal element short 10$
RS241 TELEFUNKEN (AD1) GLOBE TUBE POWER TRIODE heater ok dead no output 40$
A415 PHILIPS TRIODE BROWN BASE NOMINAL 4MA TEST 1MA 25% Europe 4-Pin 15$
UB-110 TUBE USSR NOMINAL 4MA TEST 6.2MA 150% Europe 4-Pin 35$
UB-107 TUBE USSR NOMINAL 7.5MA TEST 9MA 120% Europe 4-Pin 35$
UB-107 TUBE USSR NOMINAL 7.5MA TEST 8.1MA 106% Europe 4-Pin loose base 30$
B405 PHILIPS TRIODE NOMINAL 8MA TEST 11MA 130% Europe 4-Pin 45$
B409 PHILIPS TRIODE BROWN BASE NOMINAL 12MA TEST 4MA 30% Europe 4-Pin 15$
B409 PHILIPS TRIODE NOMINAL 12MA TEST 20MA 160% Europe 4-Pin 45$
L413(B409) VALVO TRIODE BROWN BASE NOMINAL 12MA TEST 24MA ? loose base Europe 4-Pin 25$
1599 (5U4G) METAL BASE BLACK PLATE 40 MINIMUM 1957 YEARS TEST 62\64 65\66 PAIR 80$
VO-188 ( RGN2004)Full-Wave Vacuum Rectifier Europe 4-Pin 50s 3$
BLACK PLATE 40 MINIMUM TEST 65\66 15$
VO-360 40s vacuum Rectifier 40 MINIMUM TEST 64.5 20$
5z4s (5Z4G\gz30) METAL BASE one heater for two plates!! 56 MINIMUM TEST 81\84 79\81
RARE 40 MINIMUM 1957 YEARS TEST 62\64 65\66 PAIR 80$
5z4s (5Z4G\gz30)- 1939YEARS METAL BASE no heater- display only 10$
SO-183 30s HEPTODE heater ok no output 10$
6P3S\6L6GC TEST A 250 V G2 250V G1 -14V NOMINAL 72 MA +\-14 MA(58MA-86 MA)
6P3S-E FOTON 60s 4pcs 61ma \66ma\68ma\68,5ma NEW all 55$
6L6S METAL BASE (6L6G) 1938\1940 YEAR 56MA\60 MA PAIR 100$
6P3S FOTON 50s BLACK PLATE 70MA\72MA 2 PCS PAIR 25$
6P3S FOTON 50s BLACK PLATE 64MA\64MA (MISSING KEY ) 2 PCS PAIR 20$
6P3S FOTON 50s BLACK PLATE USED 56.5MA\64MA 2 PCS PAIR 12$
6P3 FOTON 49\50s BLACK PLATE 74MA\72MA 2 PCS PAIR 30$
6P3 FOTON 49\50s BLACK PLATE 60.5MA 10$
6P3 FOTON 49\50s BLACK PLATE USED 73MA\46MA 2 PCS PAIR 12$
6P3S TANTAL 50s USED 64ma \68ma\57,5ma PCS -6$
6P3S TANTAL 50s 84MA\84MA PAIR 30$
6P3S TANTAL 50s 72MA\60MA bases dangle PCS -9$
6P3S FRJAZINO 50s USED 50ma \53ma\54,5ma PCS -7$
6P3S FRJAZINO 50s 60MA 12$
6P3S FRJAZINO 50s 72MA\70MA PAIR 30$
6P3S FRJAZINO 50s 74MA\62MA bases dangle PCS -9$
6P3S FRJAZINO METAL BASE 1949 46 MA RARE 10$
6P3 FRJAZINO METAL BASE 1946 78 MA RARE MISSING KEY 10$
6P3 NOVOSIBIRSK METAL BASE 1944 56 MA RARE MISSING KEY 10$
6P3S TELAM GOOD TEST INSIDE PARTICLES 2$
PHOTOS AVAILABLE HERE
Antique Radio Forums • View topic - FS: tube for radio
Old 23rd June 2018, 10:52 AM   #14
kszd's Avatar
6P3S test G 1- 14V G 2 - 250V plate 250V nominal 72ma +\-14ma (58ma-86ma)
6N9S (6SL7\1579) test G 1 -2,0V PLATE 250V NOMINAL 2,3MA +\-0,9MA (1,4ma-3,2ma)
6P3S FOTON 50s used lot 6PCS all 8$
(5pcs 60-68ma 1pcs 52ma)
6P3S FOTON 60s used lot 17PCS all 15$
(10pcs 60-90ma 4pcs 42ma \55 ma\56ma\58,5ma 3pcs MISSING KEY 69.5ma\48ma\54ma )
6P3S REFLEKTOR used lot 1970-80 YEAR 17PCS all 15$
(13pcs 60-90ma 2pcs 44ma \54 ma )
6P3S REFLEKTOR 36 PCS NEW 1978 YEAR GOOD TEST 4$ PCS
6P3S REFLEKTOR 6 PCS NEW GOOD TEST STRAINS OF MARKING 3$ PCS
6P3S REFLEKTOR 2 PCS NEW 1984 YEAR GOOD TEST PAIR 8$
6P3S REFLEKTOR 10 PCS NEW 1970-80 YEAR GOOD TEST 4$ PCS
6P3S REFLEKTOR 1PCS 1971 YEAR MISSING KEY GOOD TEST 2$ PCS
6P3S FOTON 60s 5PCS MISSING KEY GOOD TEST 72ma\72ma\73ma\70ma\72,5ma 2$ PCS slightly used
6P3S FOTON 60s 2PCS GOOD TEST 63ma\70,5ma 2$ PCS slightly used
6P3S FOTON 1PCS 1970 YEAR NEW GOOD TEST 4$ PCS
6P3S FOTON 50s 2PCS GOOD TEST 55ma\56ma 2$ PCS slightly used
6P3S FOTON 50s 3PCS GOOD TEST 68ma\67ma\74ma 2$ PCS slightly used
6P3S FOTON 50s 19 PCS GOOD TEST NEW 4.5$ PCS
6N9S MELZ 64-67YEAR TEST 1,9MA-2,6 MA 13 PCS 4$-1PCS
ALL 13PCS - 40$
1579(spezial-6N9S\6SL7)REFLECTOR 5\66YEAR 2,4MA\2,92MA 2,02MA\2,2MA 20$-PAIR
1579(spezial-6N9S\6SL7)REFLECTOR 62 YEAR 2,6MA\3,0MA 10$
1579(spezial-6N9S\6SL7)REFLECTOR 70 YEAR 2,2MA\2,5MA 10$
1579(spezial-6N9S\6SL7)REFLECTOR 7\71YEAR ALL 2,0-2,6MA 5PCS 10$-PCS
1579(spezial-6N9S\6SL7)REFLECTOR 76YEAR 2MA\2MA 2MA\2,02MA 20$-PAIR
1579(spezial-6N9S\6SL7)REFLECTOR 80YEAR 2MA\2,04MA 10$
1579(spezial-6N9S\6SL7)REFLECTOR 81YEAR 2,18MA\2,53MA 10$
1579(spezial-6N9S\6SL7)REFLECTOR 84YEAR 2,1MA\2,1MA 2,21MA\2,0MA 20$-PAIR
ALL 15 PCS -130$
6N9S(6SL7)TANTAL SILVER PLATE 57-58YEAR ALL 2,45-3,0MA 8PCS 6$-PCS
ALL 8 PCS -40$
6N9S(6SL7)REFLECTOR SILVER PLATE 58-59YEAR ALL 2,35-3,18MA 15PCS 6$-PCS
ALL 15 PCS -80$
6N9M(spezial-6N9S\6SL7)MELZ SMALLER SIZE 48YEAR 1,8MA\2,1MA 10$
6N9M(spezial-6N9S\6SL7)MELZ SMALLER SIZE 49YEAR 2,2MA\2,6MA 15$ MILITARY-AIR FORCE
6N9M(spezial-6N9S\6SL7)MELZ SMALLER SIZE 49YEAR 2,62MA\2,7MA 15$ MILITARY-AIR FORCE
ALL 3 PCS metal base -30$
6N9M(spezial-6N9S\6SL7)MELZ 50YEAR 2,23MA\2,4MA 20$ MILITARY-MARINE FORCES
6N9M(spezial-6N9S\6SL7)MELZ 50YEAR 2,75MA\2,45MA 20$ MILITARY-MARINE FORCES
6N9M(spezial-6N9S\6SL7)MELZ 50YEAR 2,62MA\2,6MA 20$ MILITARY-MARINE FORCES
6N9M(spezial-6N9S\6SL7)MELZ 51YEAR 2,22MA\2,38MA 20$ MILITARY-MARINE FORCES
6N9M(spezial-6N9S\6SL7)MELZ 51YEAR 2,8MA\3,6MA 20$ MILITARY-MARINE FORCES
6N9M(spezial-6N9S\6SL7)MELZ 51YEAR 2,35MA\2,6MA 20$ MILITARY
6N9M(spezial-6N9S\6SL7)MELZ 51YEAR 2,2MA\2,38MA 20$ MILITARY-MARINE FORCES
ALL 7 PCS metal base -120$
1579(spezial-6N9S\6SL7)MELZ 57YEAR 2,52MA\2,85MA metal base 45$
1579(spezial-6N9S\6SL7)MELZ 57YEAR 2,48MA\2,92MA metal base 45$
1579(spezial-6N9S\6SL7)MELZ 57YEAR 3,03MA\2,81MA metal base 45$
ALL 3 PCS -120$
6N9S(6SL7)MELZ metal base 54YEAR 2,0MA-3,02MA 19PCS 8$-1PCS
ALL 19 PCS -135$
6N9S(6SL7)MELZ metal base 54YEAR 2,48MA\1,8MA 2,32MA\1,8MA 2PCS 8$-PAIR
6N9S(6SL7)MELZ metal base 52YEAR 2,42MA\2,35MA 2,25MA\2,4MA 2PCS 20$-PAIR
6N9S(6SL7)MELZ metal base 52YEAR 1,8MA\1,7MA 5$
6N9S(6SL7)MELZ metal base 53YEAR 2,2MA\2,17MA 2,2MA\2,02MA 1,9MA\2,51MA 3PCS 8$-1PCS
6N9S(6SL7)MELZ metal base 55YEAR 2,2MA\2,0MA 2,1MA\2,0MA 2,8MA\2,65MA 3PCS 8$-1PCS
6N9S(6SL7)MELZ metal base 56YEAR 2,3MA\2,0MA 2,75MA\2,0MA 2,3MA\2,62MA 2,8MA\2,67MA 4PCS 8$-1PCS
ALL 15 PCS -110$
6N9S(6SL7)MELZ metal base ??YEAR MARKING PARTIALLY ABSENT 4PCS
2,1MA\2,08MA 2,77MA\2,8MA 2,6MA\2,32MA 2,4MA\2,4MA 6$-1PCS
ALL \4 PCS -20$
some more parts
Antique Radio Forums • View topic - FS: Sets of parts
Old 31st October 2018, 11:19 AM   #15
kszd's Avatar
TUBE G-807=807~ 6BG6G ~ 6L6G
all tested on plate current
everything is in good condition
A-300V G2-300V G1-(-20v) plate current=72MA+\-14MA
some with partially erased markings
G-807 ULJANOVSK 70`s brown base 32 pieces - $ 4 each
or all at once 110$
G-807 ULJANOVSK 70`s black base 19 pieces - $ 4 each
or all at once 60$
G-807 FOTON 60`s black base 18 pieces - $ 5 each
or all at once 75$
G-807 FOTON 50`s black\(1)brown base 5 pieces - $ 7 each
or all at once 30$
G-807 FRJAZINO 50`s black base 2 pieces - 15$ Pair
6P7S=6BG6G
6P7S ULJANOVSK 70`s black base 7 pieces - $ 3.5 each
or all at once 20$
6P7S FOTON 50`s black base 3 pieces - $ 5 each
or all at once 12$
6P42S ~ 6P45S / ~ EL509 / ~ 6KG6 SVETLANA TUBES
tested due to high current plate
on a normal tester
good-bad
all in a good green zone
6P42S high format 2 pieces new pair 15$ Pair
6P42S low format 2 pcs. new pair 15$ Pair
6P42S USED 8 pieces (6 high format 2 low) all 25$
or all at once 45$
6P45S = EL509 = 6KG6 SVETLANA TUBES
on a normal tester
good-bad
6P45S 30 pieces new $ 12 each
or all at once 320$
6P45S 33 pieces SLIGHTLY USED $ 7 each
or all at once 200$
6P45S 56 pieces USED $ 4 each
20 pieces -- 70$
or all at once 180$
Old 7th January 2019, 01:05 PM   #16
kszd's Avatar
6N23P (6DJ8\ECC88)VOSKHOD GETTER on the WIRE
19PCS ---ALL 200$
ECC189 VOSCHOD 2PCS-- 25$
tested
on an ordinary tester
good bad
6N23P (6DJ8\ECC88)VOSKHOD -250PCS
6N23P (6DJ8\ECC88)Reflector -47 PCS
1pcs -2$
50pcs-80$
100pcs-140$
tested
good bad
6J32P (EF86\6267) all tested on plate current
plate current=3MA+\-1MA
3.15ma\3.15ma\3.2ma\3.2ma\3.22ma
3.6ma\3.6ma\3.62ma\3.65ma
3.4ma\3.4ma
2.5ma\2.5ma\2.41ma\2.37ma
2.82ma\2.83ma\2.95ma\2.62ma
blue box 3.18ma\3.17ma 75year
red box 4ma\4ma\3.03ma\3.82ma 77year
all-25pcs- 100$
6F3P(ECL82\6BM8) -39PCS
1PCS- 4$
ALL-39PCS-135$
tested
good bad
6N8S MELZ -24PCS
1PCS-10$
ALL-24PCS -200$
6E6P-DRU GOLD PIN -46PCS
everything is in good condition-NEW TEST
1PCS-10$
6E6P-DR -1PCS
6E6P-E -30PCS
1PCS-3.5$
ALL-31PCS-100$
6E5P (EL183) -250PCS
1PCS-1.5$
50pcs-50$
100PCS-90$
tested
good bad
6P1P-EV LONG LIFE (6V6GT-NOVAL BASE\ ≈6П14П\el84)
NEW --250PCS
1PCS--1.5$
50PCS-50$
100PCS-90$
6P1P (6V6GT-NOVAL BASE\ ≈6П14П\el84)
--120PCS
50PCS-40$
120PCS-80$
--120PCS RARE 50 YEARS
SVETLANA \MELZ\FRJAZINO\NEVZ
4$ - 1PCS
tested
good bad
Old 13th February 2019, 04:13 PM   #17
kszd's Avatar
6P6S Svetlana =6V6GT=6V6 -Rare tube 50 year
tested - A-250V G2-250V G1-(-12.5V) I-Plate nominal 45 ма +\-12ма
price when choosing radio tubes
54-57 years 6P6S Svetlana
30-39MA- 3$ -1pcs
40-50MA - 5$ -1pcs
51-53 years 6P6S Svetlana
30-39MA- 5$ -1pcs
40-50MA - 7$ -1pcs
6P6S Reflector 50-80 years
30-39MA- 1$ -1pcs
40-50MA - 2$ -1pcs
6V6GT Svetlana -50 years 12$ - pcs
1515 (special 6V6gt ) Reflector 7$ - pcs
1515 (special 6V6gt ) Reflector-50 years 12$ - pcs
6P11S (special 6V6gt ) Reflector-50 years 15$ - pcs
6V6GT Svetlana -48 years OVAL PLATE 15$ - pcs
6P6S Svetlana 57year
36MA - 2PCS
40MA - 4PCS
41MA - 2PCS
43-44MA -2PCS
46MA - 2PCS
47MA - 2PCS
48MA - 2PCS
54MA - 1PCS
TOTAL 17 PIECES TOGETHER = 70$
6P6S Svetlana 56year
33\34MA - 2PCS
36MA - 3PCS
37MA - 2PCS
38MA - 2PCS
38MA\35.5MA - 2PCS NO KEYS
39-40MA - 4PCS
41MA-42MA - 4PCS
43-43.5MA -2PCS
48.5MA - 1PCS
53MA \55MA- 2PCS
TOTAL 24 PIECES TOGETHER = 80$
6P6S Svetlana 55year
38MA - 6PCS
38MA - 1PCS NO KEYS
39-40MA - 4PCS
42MA - 5PCS
45.5-46MA -2PCS
47MA - 1PCS
49MA \50MA- 2PCS
TOTAL 22 PIECES TOGETHER = 73$
6P6S Svetlana 54year
34-35MA - 3PCS
36MA - 4PCS
38MA - 2PCS
39.5MA\40.2MA - 2PCS
41MA-42MA - 2PCS
44MA - 2PCS
48-49MA - 2PCS
52MA- 1PCS
TOTAL 18 PIECES TOGETHER = 60$
6P6S Svetlana 53year
36-37MA - 2PCS
38MA - 1PCS
39.8MA-40.3MA - 5PCS
42MA-43MA - 2PCS
43.5-44MA - 5PCS
45-46MA - 3PCS
48MA - 3PCS
50MA - 6PCS
51.5MA - 2PCS
TOTAL 29 PIECES TOGETHER = 165$
6P6S Svetlana 52year
36MA - 1PCS
37.5-38.5MA - 4PCS
40MA\42MA - 2PCS
43MA - 1PCS NO KEYS
44MA - 4PCS
46.5MA - 2PCS
52MA- 1PCS
TOTAL 15 PIECES TOGETHER = 80$
6P6S Svetlana 51year
32MA - 1PCS
40-40.5MA - 3PCS
42-42.5MA - 3PCS
54MA \56MA- 2PCS
TOTAL 24 PIECES TOGETHER = 50$
31MA - 1PCS
32-33MA -3PCS
34MA - 5PCS
35.5-36MA - 2PCS
38MA - 1PCS MOVING BASE
39MA - 1PCS NO KEYS
37MA - 3PCS
38MA - 4PCS
39-39.5MA -2PCS
TOTAL 22 PIECES TOGETHER = 18$
40MA - 6PCS ( 1 IN BOX )
42MA - 3PCS
43-43.5MA -3PCS ( 1 IN BOX )
44MA - 8PCS ( 1 IN BOX )
45.5-46MA - 3PCS
47.5-48MA - 2PCS
49MA - 1 PCS BOX
50MA - 4PCS ( 2 IN BOX )
51MA - 2PCS ( 1 IN BOX )
56MA - 1PCS
TOTAL 33 PIECES TOGETHER = 56$
32MA - 1PCS
33.5-34.5MA - 4PCS
38-38.5MA - 4PCS
39-40MA - 4PCS
54MA - 1PCS
TOTAL 14 PIECES TOGETHER = 140$
34.5MA - 1PCS
40 MA 1PCS
41.5-42MA 2PCS
45MA 1 PCS
TOTAL 5 PIECES TOGETHER = 30$
1515 (special 6V6gt ) Reflector-60 years BLACK PLATE
42.5MA 1PCS
56MA 1 PCS
TOTAL 2 PIECES TOGETHER = 20$
6P11S (special 6V6gt ) Reflector-60 years BLACK PLATE
34.5MA - 1PCS
39.8 MA 1PCS
43.7-44MA 2PCS
TOTAL 4 PIECES TOGETHER = 52$
32MA - 1PCS
40MA - 1PCS
42MA - 3PCS
Z14 = 1N5G NOMINAL 1.2MA
G.E.C. ENGLAND 5$ - 1pcs
1.6MA\1.61MA\1.63MA\1.63MA
1.67MA\1.77MA\2MA
OSRAM BVA
1.3MA\1.42MA\1.38MA NEW-- BOX 7$ -1pcs
1.32MA 5$
1.2MA\0.8MA USED - PAIR 3$
TOTAL 13 PIECES TOGETHER = 54$
some more positions
Antique Radio Forums • View topic - FS: VARIOUS DYNAMIC SPEAKERS
Antique Radio Forums • View topic - FS: VARIOUS INDICATOR LAMPS
Old 19th July 2019, 11:04 AM   #18
kszd's Avatar
4p1l normal 35mA
4p1l 4 pieces 70th years 42ma \ 40ma \ 42ma \ 41ma ---3$pcs
4p1l 2 pieces of black anodes 53year vp172 42mma \ 48ma 20$ pcs
4p1l black anode 46ma vp22 46ma dent basement experienced 52 year 10$ pcs
4p1l black anode 50ma 50 year 10$ pcs
AZ41 3pcs new 3 pieces --8$pcs
EZ81 rate >70 new(anode current)
EZ81 TESLA 80\80 80\80 81\84 --5$pcs
EZ81 RFT 79\79 --5$pcs
EZ81 TUNGSRAM 88\86 81\84 --6$pcs
EZ81 \ 6CA4 NEC 96\95.5 --10$
EZ80 rate >60 new(anode current)
EZ80 TUNGSRAM 60\60.5 64.5\65.5 61\64.5 64.5\66 --4$pcs
EZ80 TUNGSRAM 68\69.5 traces of work 2$pcs
EZ80 RFT 65\69.5 65.5 \66 64.5\65 65\68.5 ---4$pcs
EZ80 MULLARD 66\69 64.5\65 --30 $ for 1 piece
EL83 rate 36 ma
EL83 WF 30.5ma \ 30.5ma \ 31ma --3$pcs
EL83 TESLA 30-34м 5 pieces --3$pcs
EL83 TESLA 35-38м 8 pieces --4$pcs
EL83 TESLA 39-48m 7 pieces --4$pcs
EL83 TESLA 25-40m 7 pieces for pieces of work traces--1$pcs
EL86 rate 70 ma
EL86 POLAM 70ma \ 70ma \ 70ma \ 70ma 20$--for 4 pieces
EL86 POLAM 68ma-76ma 8 pieces --3$pcs
EL86 TELAM 64ma \ 77ma 2 pcs --3$pcs
EL86 MOTOROLA holland 74ma --10$pcs
EL86 PHILIPS 71MA \ 79MA --15$pcs for 1 piece
PL84 standard 70mA
PL84 RFT 72ma --2$pcs
PL84 TESLA 67.7м \ 77м --2$pcs
PL84 POLAM 68-74м 4 pieces --2$pcs
PL84 TELAM 72.2ma \ 76ma --2$pcs
PL84 holland 74ma --5$
E180F GOLD PIN
nominal - 11.5 mA
Philips BLACK ANODE 15MA 15MA 14MA partially worn markings -10 $pcs
Philips BLACK ANODE 11,5MA partially worn markings -8 $
Philips WHITE ANODE 9 MA 10.5MA traces of WORK 5$pcs
E180F GOLD PIN
nominal - 11.5 mA
VALVO - Philips code
VALVO WHITE ANODE 8,2 MA ---3$pcs
VALVO WHITE ANOD 7.8 MA-8.0 MA 3 PCS. Work tracks--2$pcs
VALVO WHITE ANODE 10 MA \ 10.1 MA 2 PCS---3$pcs
VALVO WHITE ANOD 11.9 MA \ 11.7 MA 2 PCS -10 $pcs
VALVO WHITE ANODE 12 MA \ 12,6 MA 2 PCS -10 $pcs
E180F GOLD PIN
nominal - 11.5 mA
SIEMENS code Philips WHITE ANOD 10 MA ---4$pcs
SIEMENS code Philips WHITE ANODE 12 MA Traces of work -5 $
SIEMENS code Philips WHITE ANOD 15.5 MA Traces of work -5 $
MULLLARD WHITE ANODE 14.7 MA -10 $
E180F
nominal - 11.5 mA
TESLA 10 MA \ 10.2 MA \ 14.5 MA 3 PCS ---2$pcs
TESLA GOLD PIN 10 MA \ 14 MA 2 PCS ---2$pcs
EF861 normal 13 ma
GOLD PIN 5$ a piece box
WF EF861 14mA
WF EF861 10.3ma 9.8ma
WF EF861 8.1ma ​​7.5 ma
WF EF861 21.8 MA ---1$pcs Work tracks
WF EF861 16.5 MA ---3$pcs
WF EF861 19,5 MA 14MA additional heter ---7$pcs
6n3p = 2c51 = 6cc42
nominal 8.5ma + \ - 3ma
6cc42 TESLA D-geter 6ma \ 6.2ma 6.2ma \ 6.2ma pair ---6$pcs
6cc42 TESLA D-geter 6ma \ 6.7ma 6.2ma \ 6.7ma pair ---6$pcs
6cc42 TESLA D-geter 7ma \ 7ma 7ma \ 7.5ma ---4$pcs
6cc42 TESLA D-geter 8.1ma ​​\ 8.6ma Traces of work --2$
6cc42 TESLA O-geter 7ma 7.8ma 7.3ma \ 8ma 7.2ma \ 7.6ma 7ma \ 8ma
8ma \ 7.5ma 8ma \ 7.1ma 8ma \ 8.2ma 7ma \ 7.7ma ---4$pcs
6cc42 TESLA O-geter 6ma \ 6.5ma 6.8ma \ 7.5ma 6.7ma \ 7ma ---3$pcs
6cc42 TESLA O-geter 7.5ma \ 7.8ma Traces of work ---2$pcs
2c51 black anodes 7.8ma \ 8ma ---8$pcs
6n3p fryazino 7.9ma \ 9.7ma 9.9ma \ 7.2ma ---3$pcs
6n3p reflector 50-ies 9.2ma \ 8.2ma 8.1ma ​​\ 7.8ma 7ma \ 6.7ma ---1$pcs
6n3p photon deep hetero 10.7ma \ 11.7ma 8.5ma \ 7.5ma 7.3ma \ 8.6ma 7.6ma \ 6.7ma ---2$pcs
6n3p photon 6.5ma \ 8ma 7.6ma \ 8ma ---1$pcs
ECC85 norm 10ma
ECC85 RFT 10ma \ 10ma 10ma \ 10.1ma 10.1ma \ 10.4ma ---6$pcs
ECC85 RFT 9ma \ 10ma 9.3ma \ 9.9ma 9.6ma \ 10ma 9ma \ 10.1ma ---5$pcs
ECC85 RFT 8.2ma \ 9.6ma 8.4ma \ 9ma ---2$pcs
ECC85 RFT 6ma \ 8ma 7.6ma \ 8ma Traces of work ---1$pcs
ECC85 TUNGSRAM 10.1ma \ 10.1ma 9.8ma \ 9.8ma 10ma \ 9.5ma 10ma \ 9.8ma 10.1ma \ 9.7ma
10.1ma \ 9.2ma 11.7ma \ 11.9ma ---5$pcs
ECC85 TUNGSRAM 10.1ma \ 10.3ma 10ma \ 10ma 10ma \ 10ma 10ma \ 10.2ma
10ma \ 10.1ma 9.2ma \ 9.8ma Traces of work ---2$pcs
ECC865 WF GOLD PIN 10.1ma \ 10.2ma 9.8ma \ 10ma 9.9ma \ 9.9ma 10.3ma \ 10.3ma
11.3ma \ 11.3ma 11.3ma \ 10.4ma for $ 15 per item
ECC865 WF GOLD PIN 11.7ma \ 11.9ma Work tracks $ 7
ECC85 SIEMENS 10.1ma \ 10.2ma 15 $
ECC85 SIEMENS 7ma \ 8ma Traces of work $ 7
ECC85 BRIMAR 8ma \ 8.3ma 8 $
PCC85 BRIMAR 10.2ma \ 10.5ma 8 $
EF806S 3.2ma + 0.6ma-0.5ma steepness norm 38 min. 25
EF806S TESLA CODE FC 2.8ma \ 39 2.6ma \ 38.5 2.62ma \ 38 2.7ma \ 37 for $ 15 per item
EF806S TESLA CODE FC 3.2ma \ 40 3.42ma \ 41.5 at $ 20 per item
EF806S TESLA CODE FC 2.2ma 7 $
EF806S TESLA CODE FC 1.55m ---3$pcs
EF806S TESLA white mark 3.38m \ 3.75m \ 4m at $ 20 per item
EF806S TESLA erased mark 2.6ma 10 $
EF806S TESLA CODE DX 3.4ma \ 39.5 3.15ma \ 39.5 3ma \ 40 for $ 20 per item
EF806S TESLA RO code 3.2ma \ 39 3.01ma \ 37 for $ 20 per item
EF806S TESLA CODE HM 2.9m \ 36.5 3.7m at $ 20 per item
EF806S TESLA CODE JD 3.5ma \ 40.5 4.25ma \ 45.5 2.99ma \ 39 for $ 20 per item
EF806S TESLA CODE JD 2.2 7 $
EF806S TESLA CODE AX 3.01ma \ 40 3.2ma \ 38.5 3.4ma \ 39.5 3.58ma \ 40.5 by $ 20per item
EF806S TESLA CODE AX 3.7m \ 41 3.8m \ 42 4m \ 43 4.19m \ 44 over $ 20per item
EF806S TESLA 3.18m \ 36.5 3.2m 3.41m 3.02 2.81m $ 20 each
EF806S TESLA 2.5MA \ 29 10 $
EF806S TESLA 1.85m--3$
EF86 norm 3+ + - 1ma steepness norm 38 min. 25
EF86 VALVO 2.2m Traces of work $ 5
EF86 VALVO 2.6ma \ 39.5 2.5ma \ 38.5 2.8ma \ 36.5 2.81ma \ 39.5 Traces of work $ 10pcs
EF86 VALVO 2.97 ma \ 41.5 3ma \ 40.5 3.2ma \ 43.5 3.38ma \ 45.5 3.4ma \ 40 Traces of work $ 15pcs
EF86 VALVO 2.5ma 15 $
EF86 VALVO 2.78m \ 40 3ma \ 43 3ma \ 40.5 3ma \ 40.5 3.02ma \ 43 3.05ma \ 41.5 25 $ piece
EF86 VALVO 3.21ma \ 45 3.2ma 3.41ma \ 45 3.58ma \ 39.5 3.81ma \ 45.5 3.8ma 30 $ piece
EF86 VALVO 3.98ma \ 50 3.2ma 4.22ma \ 50.5 4.45ma 30 $ piece
Sale of special quality lampsHide this!Advertise here!
new projector lamps for sale hclampsf Vendor's Bazaar 0 4th August 2011 07:27 AM
FS Mullard CV2492 special quality E88CC matched/balanced pair #3 Andypairo Swap Meet 0 10th July 2011 07:52 AM
FS Mullard CV2492 special quality E88CC matched/balanced pair #2 Andypairo Swap Meet 0 10th July 2011 07:49 AM
TDA 1541A S1 special quality Bernhard Swap Meet 0 25th March 2007 09:49 PM
Electronic Lamps, electricity, i need help, lamps burning, needing procedure destroyer X Solid State 27 13th September 2005 09:27 AM
Copyright ©1999-2019 diyAudio
