Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
AZ OLED setup kits for Soekris dam1021/1121 control
Old Yesterday, 07:52 AM   #551
nano35 is offline nano35  Hong Kong
Smile my DAC is finished:
Hi Audiozen / other Soekris bros,
I finally finished my DAC; I just have couple questions:
1. The big transformer is the main power supply for the Soekris board obviously; I think it also powers the OLED display and other minor circuitry right?
I am thinking of trying the Salas BiB v1.3 PSU; Do I simply plug in through J7 and leave the big blue transformer as is?
2. My friend finished his DAC months ago; we bought the extra capacitors for both the base board and Soekris DAC board modding. He listened WITH and WITHOUT the 12 silver caps on Soekris board and he concluded that he did not like the sound quality of the 12 silver caps. It was worse than without.
I wonder if we bought the wrong type/value or anyone has the similar experience? I still have the 12 caps in the bag and I am hesitated to go for it.
3. I believe the IR sensor needs a hole on front panel to receive the signal from a remote? I forgot to make one; if so the case, I can live without one; it is not much to control on the dac anyway.
4. I am very happy with the audiozen board and Soekris DAC.
I own a Audio-GD NOS19 DAC-BB1704 chip-it is already wonderful; but Soekris adds an extra layer of depth, air, dynamic, detail and clarity to the same music! very excited.
The only thing I found with Soekris, when compared to NOS19 Dac, is that Soekris has a weaker bass. I wonder anyone have the same feeling and what to do to improve it?
I already set the RCA output to RAW mode; filter to "linear".
Thanks!
File Type: jpg 2e42cf83-b8d9-47c7-8844-02737487eeeb.jpg (174.8 KB, 57 views)
Old Yesterday, 11:33 AM   #552
androa76 is offline androa76  Slovenia
Can you describe what was worse, maybe we have similar problem.
Filter linear ...frimware 1.06 or 1.19?
Old Yesterday, 11:42 AM   #553
Audiozen. After some years can you do any modifications. I don*t like TPS regulator it is too harsh. Can you redeisgn board to LT3045 and lt3094?
Can i buy board without TPS soldered and capacitors, i will like to use other type of capacitors.
Thank you.
Old Yesterday, 12:27 PM   #554
audiozen is offline audiozen
@nano35
1 The big transformer is only supplied to DAM. One output of the small transformer supplies MCU , and the other output supplies power to USB.
2 I have no idea for mud caps.
3 Try change the DF of DAM or change the caps of PSU.
Old Yesterday, 12:33 PM   #555
@androa76
TPS is the best dual rail regulator chip we can find. LT3045 current is too small for PSU to supply DAM. I think parallel or amp is not a better way.
Old Yesterday, 12:51 PM   #556
Ok. For safe 2 pcs lt3045 an 1pcs of lt3094 is enough. Positive current is around 350ma negative 150ma. Rev5 even lover because of just 1 opamp. It is well known that opamp stage is bad. So if you unsolder opamps out it is even less *problematic*. Tps is not optimal for analog supply that is what we heard at testing soekris. Also FP polymer mod is not optimal. Ok noise go away on scope but midrange iss too plastic hard sounded tweets little to harsh, compare to dacs like Total dac, Analog dac, Audio note...
If positive Tps supply also part of a Audiozen board that is another story.
Old Yesterday, 01:14 PM   #557
Yes,you can ignore AZ's PSU,and use your favorite PSU. AZ design the external PSU input port.
Old Yesterday, 04:11 PM   #558
I bought the DAM1021 at the beginning of 2018, no idea what version.
I have to ask my friend what exactly is worse with the caps than without.
Are those the correct type/value caps for DAM? Any "the best" type should I get instead?Just a beginner here.
Yesterday, it was my RPi3 model B+ using coaxial for moode v4.3 and active speakers; did not like the SQ that much and not much of filter difference I could hear.
Today, I switched back to RPi3 model B with USB connection on moode v3.84 and go to my Whammy headphone amp/Sennheiser HD600 headphone. It sounded wonderful and similar to BB1704 character. The DAC filter change is quite audible.
I guess it is just the result of "mix and match" of my different hifi components. Too many little gadgets to play with.
Old Yesterday, 04:57 PM   #559
audiozen,
Thanks for the answer. I appreciate it.
I read about a dual mono balanced Dam1021 board before in this thread. Is it gonna to be available soon? just curious.
AZ OLED setup kits for Soekris dam1021/1121 controlHide this!Advertise here!
Linux servers and Soekris DAM1021 robertrowett Digital Line Level 141 26th February 2017 09:33 PM
WTB: Soekris dam1021 kcdonahue Swap Meet 1 2nd October 2016 03:43 AM
WTB Soekris dam1021-02 guglielmope Swap Meet 4 3rd December 2015 08:42 PM
FS - Soekris dam1021-02 jeremysk Swap Meet 9 16th October 2015 12:17 AM
For Sale-Soekris dam1021-05 stonehome Swap Meet 3 19th July 2015 02:38 PM
