Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
SilentSwitcher - mains-free +/-15V and 6/5/3.3V power
Old 13th July 2019, 06:50 AM   #161
maartn is offline maartn  Netherlands
Default SilentSwitcher - mains-free +/-15V and 6/5/3.3V power
Hi Jan, I am afraid that I may have hurt my SilentSwitcher. Not exactly sure what is causing it, but this is what I see:
- the -V output gives 0 V: almost no voltage difference with ground
- L3 is cracked - see attached pic, don’t know what happened there!
Do you have any suggestions on how to go about troubleshooting or fixing?
Thanks in advance,
Maarten
Old 13th July 2019, 07:19 AM   #162
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
That looks weird! Can you measure that there is input voltage on the left side of the inductor? Should be around 16V. If there is, try to temporarily bridge the inductor with a piece or wire, to see that you have output voltage. If so, it's just the inductor.
But I fear that there has been some sort of overload before the linear post-regulator. Maybe a probe or wire inadvertently falling on the board.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 13th July 2019, 06:06 PM   #163
It gets even more weird:
- I measure around 8.6 to 9 V on both sides of the inductor
- the bottom side of the board gets hot, around where the cracker inductor is
- while fiddling around I re-measured the output and I some point I did get -15 on the negative one
Could there be something broken inside L3 that causes intermittent short circuits? Or should I look somewhere else?
Old 15th July 2019, 06:33 AM   #164
jan.didden's Avatar
What you measured around the inductor probably had a lot of ripple, so the value may not be correct.
What I can suggest is if you can short out the inductor. Then output voltages should be OK (but with a bit more HF ripple) and will confirm that L3 is the culprit.
Jan
Old 15th July 2019, 07:16 PM   #165
I shorted it by holding a wire to the edges of the pads just protruding on the left side. What is see happening is that the voltage across ground and V- slowly decreases to 0 while I hold the short. As soon as I release, the voltage jumps up again. Currently I have +15 on V+ and -2 on V-. So the -2 slowly creeps to 0 when I short.
Old 15th July 2019, 07:37 PM   #166
jan.didden's Avatar
What do you see on test point V2 against ground?
Jan
Old 15th July 2019, 08:00 PM   #167
Is that the purple circle above VP2 with the “1” inside? There I measure -2V.
Old 15th July 2019, 08:20 PM   #168
jan.didden's Avatar
Yes, that means that there is a defect in the switching chip, or the freewheel diode.
Not much you can do, it's pretty much impossible to repair it.
I'll send you a PM tomorrow.
Jan
Old 15th July 2019, 08:22 PM   #169
wealas is offline wealas
I have one SS with the exact same problem, I think it happened when I used a high powered 12V supply that might be noisy. If you think you can use it to troubleshoot and improve on the design I would be happy to donate it
Old 15th July 2019, 08:29 PM   #170
jan.didden's Avatar
12V is right at the absolute limit. In normal operation I wouldn't go above 9 or 10V, so you have some safety factor.
Jan
SilentSwitcher - mains-free +/-15V and 6/5/3.3V powerHide this!Advertise here!
FS:Βib+5V IRF +, Bib 3.3V Bjt+ , 2 X Reflector 3.3V - 5.2V , Bib +/- 15V IRF nikosokey Swap Meet 16 16th March 2016 02:44 PM
Suitable chips for 15v down to 3.3v tuck1s Power Supplies 10 26th August 2015 02:53 PM
15v to 3v question graygem Power Supplies 6 10th August 2011 03:18 PM
Circuit Sanity Check: +15V, -15V, +9V Power Supply miallen Power Supplies 4 18th July 2009 07:18 PM
+/-15V power to a TI PGA2310. 15V regulators sufficient or do I need adjustable?? nick_g_evans Parts 2 16th July 2008 11:50 AM
Copyright ©1999-2019 diyAudio
