Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#421 | |||
Location: Austria, at a beautiful place right in the heart of the Alps.
![]() Quote:
But there are two IMO major issues not addressed - possible common mode errors of DAC chips - different impedance seen at the OUT of the transimpedance amp stage Quote:
I'm not after specs at all, so that point is mute for me.
Audio and Loudspeaker Design Guidelines Last edited by mige0; 11th February 2019 at 01:34 AM. |
#422 |
On the last part. I wasn't talking about spec sheet. I was talking about real world measurements. If you want I'll show you.
#423 |
I don't doubt any of your measurements.
Its just I don't care about distortion figures that much, at least not as a solely basis of decision making. In audo there are always two questions to answer IMO - how does it measure - how does it sound More often than not those answers do not go hand in hand, at least that's my experience so far
Audio and Loudspeaker Design Guidelines Last edited by mige0; 11th February 2019 at 01:46 AM. |
#424 | |
Sorry for quoting an old post, but didn't find a dedicated thread for OPA2156. Just wanted to say a colossal thank you to you and your team. 2156 is an excellent part, the best non-discrete dual I have heard ever. Popped these in my Topping D50 I-V and LPF stage and one in FiiO A5. Amazing tonality - such a sense of air, richness and sweet mids! |
#425 | |
#426 |
This was a lesson I had to learn when I first rolled to the OPA1622. Those are available for cheap on DIP8 adapter boards for plug in replacement.
Occasionally the OPA1622 at the plug in adapter board got into distortion mode with my AKG K701, some oscillation I guess. Was not able to trace it down because it worked ok as soon as I hooked up my oscilloscope. ![]() There are two measures one can undertake against oscillation / low phase margin - decoupling capacitive load by adding OUT resistors - http://www.ti.com/lit/an/slyt630/slyt630.pdf Adding OUT resistors did the trick both for the OPA1622 and later on for the INA1620 and was the first choice for lazy me
Audio and Loudspeaker Design Guidelines Last edited by mige0; 11th February 2019 at 11:05 AM. |
Thread | Thread Starter | Forum | Replies | Last Post |
New Audio Op Amp - OPA1688 | johnc124 | Vendor's Bazaar | 56 | 2nd November 2017 10:38 PM |
LME49990 Audio Op-Amp - better than AD797? | tiefbassuebertr | Solid State | 37 | 12th October 2013 08:15 PM |
Best Op-Amp for audio (guitar) | LesPaulStandard | Instruments and Amps | 35 | 15th November 2008 07:53 PM |
Op Amp Upgrade In Audio Alchemy Ditb D/a | arupg | Digital Source | 16 | 7th December 2006 09:28 AM |
New To Site? | Need Help? |
