Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
THAT Driver :: A minimalistic differential driver / preamp with 0.000021 % THD
Old 18th July 2019, 12:48 AM   #161
wcwc is offline wcwc  United States
On my THAT driver boards that I have, I am supplying +/- 15V. One will be in a phono preamp, one in a DAC, and the other one I haven’t determined what to use it for. I am using the regulator in one of my THAT driver boards since I am using it in an amp with the correct power input.
The issue with the power regulators is where are you going to be using the boards. Works Ok in an amp, but not as well in a preamp or DAC where most voltages are 15V or below. So if I have to rectify the AC to feed into the regulator on the THAT board, it is just as easy to add a regulator that can rectify the voltage and provide the bipolar voltage required.
Old 18th July 2019, 01:54 AM   #162
tomchr is offline tomchr  Canada
tomchr's Avatar
Yeah... I could also make a little SMPS+regulator board optimized for preamps. That could then be used for the Universal Buffer.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
THAT Driver :: A minimalistic differential driver / preamp with 0.000021 % THDHide this!Advertise here!
Differential Shunt Cascode Driver Ejam Tubes / Valves 21 13th September 2015 01:46 PM
Negative feedback to differential pair driver funk1980 Tubes / Valves 12 17th March 2013 06:31 PM
Differential Line Driver - Impedance Questions lehmanhill Analog Line Level 24 28th October 2012 11:01 PM
Looking for a 5V highspeed differential driver for SPDIF output wotan Digital Source 0 26th January 2012 08:32 PM
Suitable operating point for 6SN7 as a differential driver ? ray_moth Tubes / Valves 15 27th October 2004 08:50 AM
Copyright ©1999-2019 diyAudio
