Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project
Old 13th June 2019, 03:53 PM   #1241
DSP_Geek is offline DSP_Geek  Canada
Originally Posted by Tranquility Bass View Post
Just I2S with the PS Audio connection standard
cheers
That is... sub-optimal.
Off to faff about with hideously expensive HDMI to SPDIF extractors, then, and weed through the morass of 2-channel analog out plus TOSLink devices clogging the search results. Feh.
Old 13th June 2019, 07:57 PM   #1242
JamesBarr is offline JamesBarr
Am also okay with the pre-order and / or 'crowd funding'
Old 14th June 2019, 12:44 AM   #1243
The only thing which comes close is an HDMI to 4 AES/EBU extractor -- only $2400! If you can find the bloody thing, that is. Yay.
HDMI-2A - ARVUS
Everything else has TosLink for multichannel -- compressed of course -- and RCA analog outs for downmixed two channel.
If anyone else has a better idea I'm all ears.
Old 14th June 2019, 11:18 PM   #1244
Kal Rubinson is offline Kal Rubinson  United States
HDMI-2A - ARVUS
I do not follow this thread but, if it is relevant, there is a nice 8 channel USB-AES3 IO from miniDSP, the U-DIO8.
Old 15th June 2019, 05:58 AM   #1245
I could cobble together an HDMI to 8 AES output kluge from various silicon vendors' development boards, but every one of them cautions that'd work only for non-HDCP streams. Near as I can figure USB isn't crippled with copy protection / user harassing -- yet -- so USB interfaces are a relatively clean design.
In other news Arvus tells me the HDMI-2A does work with HDCP streams, and it's $1750 plus shipping from New Zealand
Old 15th June 2019, 09:59 PM   #1246
NATDBERG is offline NATDBERG  United Kingdom
I think what you mean is
" That doesn't match my requirements "
Consider that it has no HMDI or video related input at all.. you do seem to be hung up on the fact that its I2S input uses the same connector as that used in video connections... however it is an I2S input for I2S. A similar situation would be if someone saw lots of XLR sockets on the rear of their analogue pre-amp and was complaining that none of them were AES/EBU digital inputs.
Old 16th June 2019, 06:27 AM   #1247
I mean what I said. With all due respect, the unit is 95% of the way to filling my requirements, so if the HDMI connector doesn't extract audio streams from video then the specs are suboptimal for my use, not a show-stopper since I've already found an alternate solution.
In any event, T Bass looks to have something rather nice. Ta!
Old 16th June 2019, 06:51 AM   #1248
Originally Posted by orangeart View Post
Many thanks for the enthusiasm. I'm glad you like it.
It's gotten better, even though my engineering skepticism is yelling burn-in isn't real. Perhaps I'm hearing stuff not obvious from the git-go since my ears weren't used to the unit.
Anyway, the system's grown a newfound sense of s-c-a-l-e. Cool Struttin' by Sonny Clark lives quite comfortably in the room, as do Joni Mitchell, Joe Jackson, Bittersweet, and lots of friends.
Now remember the speakers have one RS-150 and one 27TDFC each. A demo to a fellow working on the house provoked the question "Where's the woofer?" "You're looking at it" He was gobsmacked, a testament to nCore's ability at plumbing the depths with aplomb.
Once again, well done. Even the chassis is brilliant, with the front panel and power button setting the right understated tone.
Old 19th June 2019, 01:32 PM   #1249
orangeart is offline orangeart  United Kingdom
Thanks for the extra enthusiasm
I've got these amps up on my website now for those who are interested. I'd rather not start a discussion about the amps on someone else's thread though. If anyone is interested I had a thread here or I can be PM'd
Thank you should also go to David for bringing the attention of you guys, his potential customers, to my amp. Thanks.
Surely building speakers could be easier...
www.kjfaudio.co.uk
Old 25th June 2019, 07:38 PM   #1250
Lotz2112 is offline Lotz2112
Hi, Im not sure, were the project stands to go into reality, I dont went through the whole chat, but:
if I can help funding this to get it going, Im very interested as well, its sounds unreal good, that finally a HighEnd DSP Preamp might be available.
Kind regards Lars
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC projectHide this!Advertise here!
Full Digital / CrossOver / Multi Amplifier integrated KOON3876 Class D 71 21st November 2014 11:56 AM
Multi channel Linux audio player with integrated amplifier questions. ollepetersson PC Based 5 17th March 2013 02:46 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
Copyright ©1999-2019 diyAudio
