Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project
Old 10th June 2019, 04:36 PM   #1231
DSP_Geek is offline DSP_Geek  Canada
Originally Posted by Tranquility Bass View Post
Yes one preamp is assigned as the master and the others are assigned as slaves and the master volume control setting is automatically carried across to all of the slave preamps in the chain. To increase the channel count you can chain as many preamps together as you like but each preamp has to be configured separately using Audioweaver. Basically it is set and forget
cheers
david
Would the LCD still be needed for the slave preamps, then?
Old 11th June 2019, 03:02 AM   #1232
Tranquility Bass is offline Tranquility Bass  Australia
Tranquility Bass's Avatar
No it's not needed but still displays master volume if it is installed
cheers
Old 11th June 2019, 11:05 PM   #1233
cheers
"If it is installed" implies some installations may not have the LCD present, interesting since the slave would be more discreet than the master.
Also: HDMI input? Really? That solves a couple of my problems.
Old 12th June 2019, 12:38 AM   #1234
All preamps come with user interface/LCD display installed but if in future there was a need for a custom higher channel count unit with multiple slave boards then it would still only require one display as the displays on the slave boards would be superfluous.
cheers
Old 12th June 2019, 05:21 PM   #1235
NATDBERG is offline NATDBERG  United Kingdom
Hi
I have prepared some info on the Ultimate Preamp 2. Let me know what you think. I will add info for the UP+ soon.
UP2 – Analog-Precision
I'm loving the green / blue flip-over panel on the webpage!
Old 13th June 2019, 01:19 AM   #1236
I uploaded the site again. See if it works for you now ? You may have to clear your browser cache as well
cheers
Old 13th June 2019, 04:13 AM   #1237
Does the HDMI input conform to the HDMI audio spec, or is it PS Audio only? A number of high end Bluray players have dedicated HDMI audio outs so plug & play would be wonderful.
Old 13th June 2019, 05:08 AM   #1238
Just I2S with the PS Audio connection standard
cheers
Old 13th June 2019, 06:40 AM   #1239
orangeart is offline orangeart  United Kingdom
Enormous thanks for the tip! The (6x250W) amp showed up Thursday so for grins & giggles I bunged in an Oppo (long live the King) BDP-83 driving a NAD 1600 preamp, with air moved by a pair of Dayton RS-150/Seas 27TDFC mini-monitors I've been dialing in. Initial listening was positive so I left the disc (Donald Fagen Nightfly) playing while doing housework. "New Frontier" came on... "waaaaait a minute, what is this texture on the snare?" Housework went straight to Hades, displaced by a more focused listening session.
Kudos to Stefan Whatcott for bringing us fine multichannel amps, and NCore is all Bruno says it is. Three mutant thumbs and a pseudopod way way up!
Many thanks for the enthusiasm. I'm glad you like it.
Surely building speakers could be easier...
www.kjfaudio.co.uk
Old 13th June 2019, 10:34 AM   #1240
cheers
There was nothing wrong exactly - just that the large coloured square has a roll-over animation, spinning over to change colour. Which is kind of entertaining when bored.
I'll clear the cache or use Chrome, maybe there's a photo there?
Anyway, it all sounds excellent - I've been holding off for DSP with at least 192KHz processing for a good while. They've always been crazy-price high end and probably much less functionality.
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC projectHide this!Advertise here!
Full Digital / CrossOver / Multi Amplifier integrated KOON3876 Class D 71 21st November 2014 11:56 AM
Multi channel Linux audio player with integrated amplifier questions. ollepetersson PC Based 5 17th March 2013 02:46 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
Copyright ©1999-2019 diyAudio
