Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project
Old 20th February 2019, 03:36 AM   #1191
bisesik is offline bisesik  Kazakhstan
Output transformers for DACs
Originally Posted by Tranquility Bass View Post
Yes I could make a special board with the interface ...
But what did you mean by this previously?
p.s. Sorry for bothering you but I need to know the situation before buying.
Old 20th February 2019, 03:37 AM   #1192
Tranquility Bass is offline Tranquility Bass  Australia
Tranquility Bass's Avatar
I thought you were referring to 8 channel input.
cheers
david
Old 20th February 2019, 03:41 AM   #1193
Well, again - no way to get 8 channel output of I2S (4xi2s) after your DSP, right?
Old 20th February 2019, 04:30 AM   #1194
Not easily and not without losing some functionality that comes with the on-board DAC. This project is more concerned with improvements that come with proper crossover design and/or room correction than it is with fiddling around the edges with different DAC architectures or vendors. Had we made the mistake of changing DAC vendors as has been previously requested of us then you wouldn't be seeing this upgraded version today and the DSP capability would have been hamstrung just because someone thought that DAC vendor A's chip had more 'fairy dust' and a wider 'sound stage' than the DAC vendor we are using
cheers
david
Old 20th February 2019, 04:56 AM   #1195
Please do not think wrong, I am very well aware of the meaning of your complete solution in terms of relevance or rationality. The question is not this, but that in some cases it is more profitable to transport the digital stream instead of the analog one. So, if you do not mind, could you briefly say what specific functionality will be lost if to use I2S before the ES90х8? So far, I see the lost of one function only - volume control. What else?..
p.s. Thank you David, I believe your answers will help others to understand your product a little clear/better.
Old 20th February 2019, 05:18 AM   #1196
Yes volume and some others to be announced
cheers
david
Old 10th March 2019, 05:52 PM   #1197
DSP_Geek is offline DSP_Geek  Canada
@David:
Do you have a rough idea when this bad boy's coming out? If it's next week I'll hold off on getting parts, otherwise I'll put together a mid-high passive xover in the interim. Either way my rack has a space marked DSP so the time frame isn't all that critical; the delivery date mainly affects whether or not I buy a pile of coils & caps for testing purposes. Thanks!
Old 11th March 2019, 03:37 AM   #1198
Originally Posted by DSP_Geek View Post
@David:
Getting closer to the mark but even if I could offer a pre-order today it will take a while to get the number of orders needed and then the delivery will be quite a few weeks after that so you may have to make do for the time being.
Currently working on the updated Digital Audio Interface (DAI) board. Here are some 3D models of the final version FYI.
cheers
Old 11th March 2019, 04:20 PM   #1199
No worries, all good in the hood. I'll have fun banging out a couple more passives & getting my FIRs in a row for later.
By the way, for those of us not completely enamored with SPDIF guessing at sample clocks, will there be an I2S option?
Old 11th March 2019, 04:45 PM   #1200
Badge is offline Badge  United States
I hope no one is holding their breath in anticipation
The freaks stick together, they are a tight old crew
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC projectHide this!Advertise here!
Full Digital / CrossOver / Multi Amplifier integrated KOON3876 Class D 71 21st November 2014 11:56 AM
Multi channel Linux audio player with integrated amplifier questions. ollepetersson PC Based 5 17th March 2013 02:46 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
Copyright ©1999-2019 diyAudio
