Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Modulus-86: Composite amplifier achieving <0.0004 % THD+N.
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. Please consider donating to help us continue to serve you.
Old 21st November 2019, 11:00 PM   #2431
tomchr is online now tomchr  Canada
tomchr's Avatar
No. The THD of the amp is below the integrated noise of the analyzer.
The only way I can measure the true THD of the amp is by using a precision oscillator. Even then, I run into trouble as the analyzer section of the APx525 "only" has 125 dB dynamic range. I.e. its internal distortion is -125 dB. I'm working on getting some filters together such that I can attenuate the fundamental, thus, measure the distortion residual.
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 27th November 2019, 10:16 PM   #2432
Sinthomnison is offline Sinthomnison  Spain
Hi Tom,
I have doubts about the construction of the mod-86 as it will be paired with my Yarra Melbourne DB preamplifier (16dB gain).
Should I lower the gain of the mod-86 with THAT1206?
The speakers have an impedance of 8 Ω and 90dB/W/m.
Thank you
Old 28th November 2019, 07:43 PM   #2433
tomchr's Avatar
I would throw in a pair of THAT1206 when you place your order with Mouser. They're not very expensive. If you have trouble getting to a low enough volume level, swap the THAT1200 for the THAT1206.
Tom
Old 28th November 2019, 08:49 PM   #2434
zgtc is offline zgtc  Europe
zgtc's Avatar
Modulus-86: Composite amplifier achieving &lt;0.0004 % THD+N.
Tom
THAT1206 is apparently no longer available at mouser?
Old 28th November 2019, 08:55 PM   #2435
poseidonsvoice is online now poseidonsvoice  United States
poseidonsvoice's Avatar
Looks available in Farnell U.K.:
https://uk.farnell.com/that-corporat...=GRHB-OCTOPART
Best,
Anand.
Science is not a democracy - Earl Geddes
DIYAudio is a journey not a destination!
Old 28th November 2019, 09:00 PM   #2436
Thank you, Tom. I appreciate your comments.
Old 28th November 2019, 09:04 PM   #2437
I found this in Mouser: https://www.mouser.es/ProductDetail/887-1206P08-U
Old 28th November 2019, 09:16 PM   #2438
zgtc's Avatar
Originally Posted by Sinthomnison View Post
My bad, thank you!
Old 28th November 2019, 11:20 PM   #2439
tomchr's Avatar
Yeah. Available at Mouser Canada as well. Search for the manufacturer's part number (1206P08) and you shall find.
Tom
Old 1st December 2019, 05:37 PM   #2440
Nightpuma is offline Nightpuma  Norway
Hi.
Just a quick question. Will it be a good option to build the Mod-86 with a volume control as an integrated amp?
Modulus-86: Composite amplifier achieving &lt;0.0004 % THD+N.Hide this!Advertise here!
LT 1226 THd ? myhrrhleine Parts 1 10th April 2014 03:46 PM
New type Zobel = <THD Zero D Solid State 7 7th May 2013 10:49 PM
OT: how can I measure THD of my amplifier if my sound card is 0,02% THD ? ygg-it Solid State 1 13th June 2010 08:54 AM
0.0004% THD Class D Module Lars Clausen Class D 16 13th November 2005 03:15 PM
Copyright ©1999-2019 diyAudio
